View Poll Results: What is your MPG?
under 15 MPG
53
25.48%
15-18 MPG
89
42.79%
18-20 MPG
56
26.92%
over 20 MPG
4.81%
Voters: 208. You may not vote on this poll
#MPG Discussion
Old Apr 6, 2019 | 07:05 AM
  #391
chimes's Avatar
chimes
Originally Posted by Airpirate
Did old fashion method and compared that to the digital read out (avg since fill up). On my 2013 the digital results were exactly the same as manual measurement.
Where are you finding the digital readout?
Old Apr 6, 2019 | 09:11 AM
  #392
bbqsoup's Avatar
bbqsoup
Push the little rocker on the steering wheel until you see Mileage since refuel or something like that.
I also use the Fuelly App to track as well.
Old Apr 6, 2019 | 10:05 AM
  #393
chimes's Avatar
chimes
Ah thank you
Old Apr 6, 2019 | 10:08 AM
  #394
Acrad's Avatar
Acrad
Also fuel consumption info within infotainment system. Graphics probably look different on '14+
Old Aug 7, 2019 | 06:01 AM
  #395
tigmd99's Avatar
tigmd99
Default BFG KO2...how bad is the drop in MPGs?
For those who have BFG KO2...what size? How bad is fuel economy drop?
Thanks.
Old Aug 7, 2019 | 08:45 AM
  #396
Airpirate's Avatar
Airpirate
Default BFG KO Fuel Mileage
Thanks.
This summer, we did a 6000 mile road trip throughout the western US. The GX was packed to the gills, and we got 20mpg on flat, straight, Interstates. City driving seems to be stuck around 14mpg. On the mountain highways (we crossed the Continental Divide four times), we averaged maybe 18mpg. I'm thinking the difference between stock 265/60 Pirellis originals and our new 265/65 KOs is 1 mpg. The handling seems a tad more solid. The noise is slightly more, but the looks and handling are well worth the slightly increased noise and slightly decreased mpg.
Old Aug 7, 2019 | 08:47 AM
  #397
tigmd99's Avatar
tigmd99
Is the road noise very noticeable? Or just over certain surfaces?
Old Aug 7, 2019 | 11:13 AM
  #398
R3loader's Avatar
R3loader
For me the noise is barely noticeable if any difference comparing to stock. I am running 285/70/17 and my mileage took about 1-2MPG hit around city driving. I think these tires are a lot heavier than stock so the added unsprung weight is causing lower mileage as expected especially when doing lots of stop and go.
Old Aug 7, 2019 | 12:41 PM
  #399
ASE's Avatar
ASE
Are you using the MPG as reported by the computer ? ... how is that calculated ? ... going from 265/60-18 to 265/65-18 is a 3% difference in circumference (distance traveled per rotation) ... so if the computer is calculating MPG based on tire rotations (distance) against fuel consumption, you did not have a drop in MPG with your new tires given you are actually traveling farther than your computer thinks you traveled, so the MPG is better than reported by the computer. 265/60-18 = 661 revs-per-mile ... 265/65-18 = 639 revs-per-mile.
Old Aug 7, 2019 | 03:27 PM
  #400
Airpirate's Avatar
Airpirate
There IS a noticeable noise increase. If the desire is to mount a larger, more aggressive tire and have the exact same noise level as original street tires, you will be disappointed. All I can say is that I am not disappointed in the slight increase in noise. It is just not that big of a thing, considering the improved traction in mud and snow and a better look.
Old Aug 8, 2019 | 07:37 AM
  #401
Airpirate's Avatar
Airpirate
I have carefully measured the fuel consumption by actual distance travelled divided by actual fuel consumed. The electronic calculation has matched this exactly, and I agree that it should be off slightly due to slightly higher tire diameter. However, after several comparisons to actual fuel consumption measurement, the digital readout remains identical. The speedo remains accurate compared to actual distance/time measurement also. Not sure how this is happening.
Old Aug 8, 2019 | 07:42 AM
  #402
tigmd99's Avatar
tigmd99
Have you noticed your car being more sluggish while driving...say merging onto the highway? Do you feel the GX struggling more to pass other cars?
Old Aug 8, 2019 | 07:51 AM
  #403
Airpirate's Avatar
Airpirate
The GX performs exactly as it did with the original tires, which is "sluggish". The V8 power is there, but one needs to really put the foot down to get that power. I'm guessing that Lexus has set throttle "tip in" to be very smooth at the expense of responsiveness.
Old Sep 6, 2019 | 01:07 PM
  #404
Craigyyy's Avatar
Craigyyy
Default IT'S POSSIBLE Y'ALL 20MPGs
Was a little surprised to see this coming back home in the labor day traffic. Lots of 50-75mph traffic, kept me from my usual 80-90. Included a decent amount of stop and go, plus awhile idling, so not 100% highway.
No doubt you could hypermile these things deep into the high 20s.
Old Sep 6, 2019 | 01:15 PM
  #405
dumbastard's Avatar
dumbastard
how accurate is the MPG on that trip meter on the GX460?
Is it pretty close to hand calculation at a gas pump?
