Alternator: should I replace?
Old Mar 27, 2026 | 01:56 PM
EricE555's Avatar
EricE555
Default Alternator: should I replace?
So my 2013 Lexus GX460 left me stranded today. Dead battery after just driving it normal for 20 minutes at freeway speeds and turning it off. Tried to restart about 20 minutes later. No battery. I got a jump then, when at home, I tested the 3 year old interstate battery with a load tester, tested ok, not great, very low end of OK. Also tested the DC Voltage at idle and revving. 13.6 at Idle, 13.75 at 3K revs. I talked to a Lexus tech who said the DCV supplied is low but maybe not ready for a replacement yet. To me, if it is not supplying 14.4V then it is not adequate.
Your opinion? (because I am on the fence for a $450 replacement unit)
Old Mar 27, 2026 | 04:26 PM
mike202's Avatar
mike202
The fact that you drove home after a jumping a dead battery suggests that the alternator is working.
The SM says voltage between 13.2V to 14.8V @ 2000 RPM is within spec. The fact that you drove home after a jumping a dead battery suggests that the alternator is working.
I would replace battery, it may be on its last leg.
Old Mar 27, 2026 | 04:28 PM
Framestead's Avatar
Framestead
how did u load test the battery?
Old Mar 28, 2026 | 06:43 AM
Toejab's Avatar
Toejab
well you're interested battery is a very good brand known for its quality if it's only 3 years old I would assume it's still under warranty. Go back to where you bought it have him test it and go from there
EricE555's Avatar
EricE555
Originally Posted by Framestead;[url=tel:12051790
12051790[/url]]how did u load test the battery?
i have a commercial load tester for the purpose.
Old Mar 28, 2026 | 06:45 AM
EricE555's Avatar
EricE555
yes. I have decided to replace the battery first then see how it goes.
Old Mar 28, 2026 | 08:58 AM
Framestead's Avatar
Framestead
I would check any parasitic draw if this continues
Old Mar 28, 2026 | 04:31 PM
Gbowie33's Avatar
Gbowie33
6th Gear
Default Battery issue
I would definitely check for a parasitic draw first. If it's within spec > 50ma, I would recommend upgrading your battery. Lexus has 710 CCA battery that fits perfectly. I live in the northeast. It definitely helped during the winter. Another test to try, don't raise the RPM'S, check battery voltage at idle with as many electrical systems turned on as you can. All the lights, radio, rear glass/mirrors, and blower motor on high. If you are at 12v your alternator is fine.
Old Apr 1, 2026 | 12:49 PM
Randyman's Avatar
Randyman
I see my DC V+ in the 12.9v-13.5v range - your 13.6v is not "Low" in any way. 14.4v was a standard a while back with "dumb" regulators, but not really a modern standard due to CAFE and fuel efficiency BS (they just have the alternator regulated tightly - just enough to supply running current, and to charge the battery as not to increase parasitic engine power draw via the drive belt). Surprised a seasoned mechanic told you to expect 14.4v on a "Modern" vehicle...
Old Apr 13, 2026 | 07:54 PM
DanTeSlagX's Avatar
DanTeSlagX
Any aftermarket remote starters or hardwired dash cams?
interstate is a good battery but they are not what they used to be. I wish we could get OEM Panasonic batteries in the USA.
Old Apr 14, 2026 | 05:59 AM
EricE555's Avatar
EricE555
Originally Posted by DanTeSlagX;[url=tel:12057653
12057653[/url]]Any aftermarket remote starters or hardwired dash cams?
nope, nothing non-stock installed. I replaced the battery and i have been out of town since. Ill check it when i get back in 1.5 weeks.
arrowroot
RX - 4th Gen (2016-2022)
Feb 9, 2023 08:34 AM
uibalnme
May 21, 2022 06:05 AM
bmgs400
Feb 3, 2020 07:41 AM
DMPesso
Nov 16, 2014 07:26 PM
Bocatrip
May 31, 2012 12:50 PM
