Key Fob Battery
Old Jan 18, 2025 | 02:25 PM
catdaddylo's Avatar
catdaddylo
Default Key Fob Battery
How often should you change the battery in your key fob? Does the GX have a warning light when the battery needs replacing?
Old Jan 18, 2025 | 04:13 PM
Framestead's Avatar
Framestead
The manual has a specific time frame but the vehicle will warn you in the mid.
Old Jan 18, 2025 | 05:36 PM
ASE's Avatar
ASE
... seems to be about every 3-years ... just had dash warning go off last week ... "2016" Coin Battery ...
Old Jan 18, 2025 | 10:03 PM
Randyman's Avatar
Randyman
My 2017 Premium uses a CR1632 - a smaller diameter than 2016/2032. Your '22 might be different as I recall my GF's 2021 NX uses a CR2032.
Old Jan 18, 2025 | 10:24 PM
Framestead's Avatar
Framestead
2020+ went to the LC style remote with 2032. The battery access cover might be different though on the 23s but the remote design is the same externally. as the 20+.
Old Jan 24, 2025 | 06:57 PM
catdaddylo's Avatar
catdaddylo
Not to change the subject but today I took my GX in for a 20K service and my vehicle battery needed replacement. Dealer replaced with a new battery under warranty. I will probably go ahead and replace the key fob battery even though I have not gotten a dash message to do so.
Old Jan 25, 2025 | 06:25 AM
mcomer's Avatar
mcomer
Be certain to move the fob(s) more than three (3) feet from the car while parked and shut off. If the fob is within the sensor range, it will continue to communicate, and the fob battery will deplete very quickly.
Old Jan 25, 2025 | 08:05 AM
ASE's Avatar
ASE
^ ... and someone can easy steal your GX ...
Old Jan 25, 2025 | 07:04 PM
Framestead's Avatar
Framestead
If you rely on one keyfob, put the other one into deep sleep.
Old Jan 26, 2025 | 04:24 PM
catdaddylo's Avatar
catdaddylo
How do you put the spare in deep sleep?
Old Jan 27, 2025 | 06:17 AM
mcomer's Avatar
mcomer
The keyfob shown does not have the easy shut down feature but the newer "squarer" style does.
With those, you can press and hold the "lock" button and while holding you then press the "unlock" button twice.
The small red guide light will then blink four (4) times, and the fob is now deactivated.
Useful if you intend to leave the car and engage in activities that a $350, non-waterproof and heavy fob would interfere with.
Biking, hiking, canoeing, swimming...
If you stand outside the car with the door open and use that technique and then slide the mechanical key out of the fob,
you can then place the fob out of sight inside the car and close the locked door. Take the light and waterproof key with you
and when you get back, use it in the driver's door key cylinder. Recover the fob and press and button to wake it up.
Note: many newer Lexi have a Very inconvenient key cylinder cover that makes this previously simple operation a B*!*h!
NTM
NX - 2nd Gen (2022-current)
16
Sep 5, 2025 09:16 AM
Lunfengzhe
14
Jul 21, 2025 04:16 PM
charliecla
LX - 3rd Gen (2008-2021)
Nov 16, 2022 02:40 PM
dotbowels
RX - 4th Gen (2016-2022)
Sep 29, 2021 03:59 AM
Out2L8
Jun 5, 2010 03:35 AM
