Shift knob
Old Sep 23, 2024 | 08:53 AM
OhioGX23's Avatar
OhioGX23
Default Shift ****
Question if anyone could help. Have a 2023 GX and was thinking of replacing the shift **** for this one. Can anyone confirm it would be a direct swap and fit? Thanks for you time and help as always.
https://www.ebay.com/itm/15550140334...&ul_noapp=true
Old Sep 23, 2024 | 09:52 AM
GrizzlyClint's Avatar
GrizzlyClint
I like that shift ****. I imagine the threads are the same, it would boil down to if the leather boot clip would clip on the bottom of that LC Prado ****.
Old Sep 23, 2024 | 09:57 AM
OhioGX23's Avatar
OhioGX23
Exactly what I was wondering. Just didn't want to buy it and than be out of luck.
Old Sep 23, 2024 | 11:18 AM
GrizzlyClint
It is fairly expensive to run an experiment on. LOL
Old Sep 23, 2024 | 03:34 PM
Misteracng's Avatar
Misteracng
By the picture, the clear clip on the bottom looks like it does not fit the 22/23 models. It looks quite tall which is the previous version. You would need to get a new shift boot from the previous GX460 and then attach that to the current plastic surround frame, then it should work. The actual metal rod is unchanged.
Old Sep 24, 2024 | 07:15 AM
OhioGX23's Avatar
OhioGX23
Thanks for the help. I believe this would be the right shift boot to change out? Part#: 58808-60402-C1. Do you think both the **** and new boot would work on my 2023? Preciate the assistance.
https://parts.belllexusnorthscottsda...0860402C1.html
Old Sep 24, 2024 | 07:29 AM
GrizzlyClint
Think it'll fit a 2010-2013?
Old Sep 24, 2024 | 07:51 AM
Misteracng's Avatar
Misteracng
Yes that boot should work, the boots and shift **** changeover was 2010-2019 and then 2020-2023 was the new version. Keep in mind there are several variations of the boot based on interior color, but that one should work well. The boot is not an exact fit on your 2023 boot frame, but it will fit. Then you can use any 2010-2019 shift ****.
Misteracng's Avatar
Misteracng
2010-2019 I think were all the same boots and shifts *****
Old Sep 24, 2024 | 08:01 AM
OhioGX23's Avatar
OhioGX23
Awesome and will be giving it a shot and let you know how it turns out. Thanks for the help truly appreciated.
Old Sep 24, 2024 | 09:14 PM
Misteracng's Avatar
Misteracng
Also you might be able to find a shift boot on ebay. Search for GX460 shifters. There are many parts out there, many times they come with a shift **** as well. It might be cheaper then buying new.
socaligs
GX - 2nd Gen (2010-2023)
May 30, 2024 10:45 PM
mferraro
Aug 31, 2020 08:58 AM
isam250
General Classifieds
Aug 18, 2015 06:56 PM
MikeLane
Maintenance
Feb 2, 2004 12:33 PM
