Master Window control does not turn off and drains battery
Old Dec 19, 2022 | 07:04 PM
RenBrant's Avatar
RenBrant
2nd gear
Default Master Window control does not turn off and drains battery
Hello everybody.
The battery on my 2006 GX470 is draining when the car is off for more than 2 days. Analyzing the circuits with a multimeter, I identified that the Power Window Master is responsible for continuing to consume 0.2A even after the car has been turned off for a long time. If I disconnect it, the drained current drops to 0.01A, that is, this is the culprit.
Has anyone ever experienced this?
Is this part repairable?
Is there anything I should do or should I go for a replacement?
Unfortunately, I don't know anyone who owns this car so I can test whether replacing it will fix it.
Old Dec 20, 2022 | 04:55 AM
chiph9's Avatar
chiph9
I have not taken one apart, but there is a circuit card in there and the wiring diagram indicates it's on the CAN network, so it's likely the microcontroller in there is not going to sleep.
There are chinese-made replacements available on aliexpress and they're cheap at 20-30 euros.
Dealer price for an OEM part is in the $800 range.
From pictures, the chinese ones aren't a good color match. I have no opinion on their quality, but at the price it may be worth a try.
It's probably worth taking apart to see if there's any damage to the circuit card, a bridged trace from debris? Or perhaps water damage?
Chip H.
Old Dec 20, 2022 | 03:08 PM
RenBrant's Avatar
RenBrant
2nd gear
I already ordered another chinese on Amazon. Let's see if it works.
Thanks for the answer.
Old Jan 18, 2024 | 11:09 AM
jtmx80's Avatar
jtmx80
1st Gear
I have the same issue! Any update on the cheap Chinese knock off?
maiahsdad
Oct 28, 2021 10:08 AM
akhosravi
Jul 26, 2019 07:10 AM
allicedout
Apr 7, 2014 11:48 AM
heab0774
GX - 1st Gen (2003-2009)
Nov 5, 2011 10:17 AM
momoko
Oct 9, 2006 12:48 PM
