Help with the Tire Pressure Warning Light
Old 09-22-18, 03:20 PM
gebo
gebo's Avatar
Default Help with the Tire Pressure Warning Light
GX doing great. Got a new set of Michelins Tire pressure was 35 on 3 tires and 42 on one after setting over night. I let air out of the 42 lbs tire and dropped it down to 35 like the other three. Now the tire pressure light is on. I deleted the code but it still comes back. I pressed and held the button on the dash around the right knee area. No change.
After you get a new set of tires installed, what exactly do you do to reset this sensor?
Or...do I have a problem. I have read the manual but it only confuses me.
Old 09-22-18, 08:24 PM
s0hcsleepe
s0hcsleepe's Avatar
Check the pressure on the spare tire. There's a tpms on it and if low will keep the light on.
Old 09-23-18, 05:56 AM
chiph9
chiph9's Avatar
Is the light on solid or is it flashing?
Solid means low pressure. Flashing means the system as a problem, like lost communication with a sensor (usually because it's battery died)
Something I regret not doing was replacing all 5 sensors when I got new tires. Over the next 2-3 years I had to pay (one at a time!) to get the tire demounted, new sensor installed, tire remounted and balanced, when the mounting/demounted would have been covered as part of getting new tires.
aasim305
06-18-15 10:45 AM
tyb2639
GX - 1st Gen (2003-2009)
01-21-12 07:08 PM
LIMS407
01-24-11 07:07 PM
lifeisgood
09-23-06 06:08 AM
Quick Reply: Help with the Tire Pressure Warning Light
