GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
HID Fog Light conversion
Old 12-27-05, 04:51 PM
robinzon
robinzon's Avatar
Default HID Fog Light conversion
Hey all,
I have not seen any posts with pics of HID Fog light conversions?!?
That is, since the wiring of the H3 bulb is essentially INSIDE the housing (ie the wires go from the bulb to the back of housing in which the wiring harness is hardwired) has anyone seen a kit that can be plugged into the original harness and then contains its own backlplate that goes into the housing?
The only way to do it right now is to run the two wires for the bulbs through a vent hole (or drill one at worst).
if someone did do the install please share some of the pictures of how it was done... (ie the back of the enclosure) and if someone has seen a Lexus specific kit please let me know.
Thanks
Old 12-28-05, 11:24 AM
robinzon
robinzon's Avatar
so no one installed H3 FOGS? I saw a couple of posts... again I just need to figure out how to do it withouh running wires in/out the enclosure of the fog
Old 12-28-05, 12:58 PM
KVA
KVA's Avatar
It should be very easy with the toughest part being where to run the wires...
Many people have done this mod with the GS (I also did it)...
Old 12-28-05, 02:20 PM
robinzon
robinzon's Avatar
Well if you have some links do post them. As I said you would need to run the wires from the BULB to the outside of the enclosure through the vent holes and then run the wires from the ballast to the harness back into the enclosure... is that what you have done? please elaborate..
Old 12-30-05, 11:13 AM
DavidsGX
DavidsGX's Avatar
For the HID fog light conversion, drill holds are needed in the back of the housing in order to let the wire to run through. I will post some of the pictures later.
Old 01-04-06, 06:09 PM
DavidsGX
DavidsGX's Avatar
Default Got the Pic!
Here is my HID Foglight - 6000K from xenondepot. I had it installed long time ago, but didn't have time to post it... Now.... it's here!! IMO, it's bright, much better vision in dark.
Old 01-04-06, 06:19 PM
DavidsGX
DavidsGX's Avatar
Default Both Low and Fog...
I looks blue because of the effect of my camera, in reality, looks almost white
Old 01-04-06, 07:21 PM
purplehazek4
purplehazek4's Avatar
david,
how is the glare from the foglights? i've been looking into adding yellow hid foglights on my GX.
do you ever get hi-beamed?
dan
Old 01-04-06, 08:06 PM
DavidsGX
DavidsGX's Avatar
The glare is so spread out wide, not far, but increases the visiblity by 10X more thenn the .
I did the PIAA iron yellow 2500K before, althought it's better than stock but I think is nothing comparable with the HID.
I found Getting a high-beam HID is not too practical for me... So I just brought PIAA 7500K from Japan, When it's on, not too bright, I just love the blue/white color!
Old 01-04-06, 08:49 PM
DavidsGX
DavidsGX's Avatar
Default Dan.... check this... Those are my old pictures...
Old 01-05-06, 01:35 PM
wld
wld's Avatar
Hi DavidsGX,
Wondering how large a hole should be drilled in the fog light housing? Also, do you have any pics?
Old 01-05-06, 01:44 PM
DavidsGX
DavidsGX's Avatar
It should be just enough for two wires running thorugh, and seal it. This way, no water will go in.
A shop did it for me, just $50...
Old 01-09-06, 06:12 PM
joeGX470
joeGX470's Avatar
Originally Posted by robinzon
Hey all,
Thanks
I have a solution to your problem.
Just pay someone to do it since you too stupid to do it or too cheap to get it done right.
Slap yourself for me! thanks
Old 01-19-06, 02:00 PM
robinzon
robinzon's Avatar
Actually its possible to take off the AMP connectors off of the bulb wires then run the wires THROUGH THE VENT HOLE on the back of the lights and run the HARNESS wires through the same vent hole and connect them to the original harness w/o cutting/splicing/drilling anything.
Thanks
tonyly
02-09-18 07:56 PM
RayLai417
12-05-11 01:34 AM
strat1
Lighting
15
02-20-06 09:46 PM
robinzon
01-12-06 09:23 PM
Quick Reply: HID Fog Light conversion
