Electrical problem
Old Sep 27, 2022 | 03:08 PM
Luap's Avatar
Luap
Default Electrical problem
Where do I start
Miles 182K
Left turn blinks fast
No low beam
All lights in area of speedo and tach area are on and some are blinking .
AC jumped to high speed and stops when I let off the gas .
Speedo stops working .
So , I stop the car , restart it and all is fine , then the battery light comes on.
Then all the above happens .
This has happened 4 times since yesterday .
Old Sep 27, 2022 | 07:38 PM
tz693's Avatar
tz693
Start with checking or replacing the battery
Old Sep 28, 2022 | 06:18 AM
IanB2's Avatar
IanB2
Not an electrical guy, but I'd start with a multimeter and see what the voltage reads across the battery terminals when the truck is off, and when it's running as a starting point. The battery light should indicate an issue with the charging system, the rest of the symptoms are confusing...you've got to start somewhere.
Old Sep 28, 2022 | 06:33 AM
Luap's Avatar
Luap
New battery , that's not the problem.
Luckily , we ahve a mobile auto electric service in my area .
Verde Valley Auto electric
Left message last night
Old Sep 28, 2022 | 04:23 PM
IanB2's Avatar
IanB2
Maybe not the battery, but another component of the charging system. May be related to why you had to replace the battery as well.
Old Sep 28, 2022 | 08:31 PM
Luap's Avatar
Luap
Auto electric guy says it's the alternator
Old Sep 29, 2022 | 10:45 AM
Davenlei's Avatar
Davenlei
Let us know if replacing the alternator fixes your problem. Crazy symptoms..... I was about to ask if any wires were chewed by rats...
Old Sep 30, 2022 | 09:11 AM
Luap's Avatar
Luap
Autozone says alt and battery okay.
Would be embarrassing if it were rodents as I own a pest control company , although , I have not seen and evidence like fecal matter around
Old Oct 4, 2022 | 05:45 AM
Luap's Avatar
Luap
It appears it's a alt replacement job , completed later today.
Low beams and 1 one signal bulb burned out at same time , that's odd
tshawn63
Nov 13, 2017 08:14 AM
Otterlex
Sep 12, 2012 05:29 PM
Lippy382
Jul 13, 2007 07:01 PM
sgv_bum
RX - 1st Gen (1999-2003)
Oct 25, 2006 09:24 PM
antony80
Sep 11, 2003 09:51 AM
