GX470 passenger heat problems
Old Feb 16, 2021 | 08:58 AM
Rc07333's Avatar
Rc07333
Default GX470 passenger heat problems
Hello all,
I've read through several heater threads and none seem to point me correct so I figured I'd just ask.
My passenger side heat isn't heating up.
I've checked the passenger vent control motor and it works. My fluid was just flushed, changed and burped by a trusted dealership.
My driver side heat works great, and when I close the driver side vents the passenger side warms up to almost as high as driver, as soon as I open driver vents it cools down immediately.
I'm wondering if it's an issue with the heater core? Does th GX have dual heater cores? Could it be an issue with the heater valve?
Thanks all!
Old Feb 16, 2021 | 06:31 PM
chiph9's Avatar
chiph9
Have you run the A/C system diagnostics? There's a thread here with the details of how to do it and what the codes mean.
Chip H.
Old Feb 17, 2021 | 07:58 PM
BT3100's Avatar
BT3100
Check your damper arm
Old Feb 18, 2021 | 07:42 AM
Rc07333's Avatar
Rc07333
https://youtu.be/q6t9iCBS_Dw
I did inspect that arm it appeared to m moving correctly and with full motion but, I'll definitely check again.
As for the climate system check, I have an aftermarket system, I don't have a climate control buttons to initialize the sequence.😓
Old Feb 28, 2021 | 06:12 PM
Rc07333's Avatar
Rc07333
So I put my oem nav back in to rerun th climate diagnostics. Received codes 21 and 24. 21 is the light sensor, but it was at night so chalk it up to no sunlight.
24 is the magnetic latch for the Ac. Just to be sure, I changed that and th codes still show when running diagnostics.
it's really strange. It's like having two complete separate heater cores. The passenger side, even the defroster is cold, while the left driver side is very hot, and the center driver side is very warm.
I'm really at a loss. All of the motors appear to be working. I've taken the glove box out to see the actuators and they seem to be working well.
Old Mar 3, 2021 | 08:31 AM
BOFF's Avatar
BOFF
So dealership didn't catch the issue?
How long ago was the work done?
God Bless,
David B.
Hoovey689
Feb 16, 2021 08:40 PM
6SOARER
Jan 18, 2015 11:48 AM
chivasc
Jun 15, 2010 09:57 AM
