This is a strange one
On my way to work I started getting a rumble strip vibration feeling from the rear end. I car pool , so we took the other ride in.
When I got back to my 08 GX470 , I could not repeat the vibration on a 15 mile run. Tires are fresh and balanced.
What could cause a strong vibration and just stop the next time driven? Thinking some thing in powertrain is about to fail. Any thoughts?
I will post if they find anything . I have no drips under it ,
What problems would a soft airbag lead to?
Brake caliper sticking? A bag wouldn’t cause rumble strip feeling. has the driveshaft been lubricated at all the points? It’s easy to miss one I know I have
A bad air spring would have it riding on the bump stops, and that would be a rough ride.
If you haven't replaced the air springs yet, you're probably due.
If you have a warm garage, park it in there, spritz some soapy water on them, then cycle through the high-normal-low positions to see if there are any deep cracks in the rubber, looking for bubbles.
Chip H.
Chip H.
I might as well have the Transfer case serviced while it's there.
No tow hitch on it, 150,000 now. I see people saying to use the 75/90 syn gear oil for the differentials and Transfer case. Opinions?
The problem never repeated itself over the last month. Had my garage friends look it over for a good once over anyway. All is well and fluids are still good in the driveline.
Now if I could just keep that new gas cap tight enough to seal and not kick codes every other fill up!
