Lugnuts for TRD Pro wheels
Old Nov 26, 2020 | 03:15 PM
chiph9's Avatar
chiph9
Default Lugnuts for TRD Pro wheels
After looking up how much the black Toyota nuts are ($11-12 each, so over $265 for a set), can I run the stock GX lugnuts on these wheels?
Running cheap Chinese eBay lugnuts are not an option.
Thanks.
Chip H.
Old Nov 27, 2020 | 01:52 PM
Lexus4321's Avatar
Lexus4321
OEM's are hub centric? I think they are.
As long as the TRD rims can be hub centric (native or with hub rings), if the OEM mag lugs fit then you should be just fine.
Old Nov 27, 2020 | 04:54 PM
chiph9's Avatar
chiph9
I found this FAQ which says "yes you can use the OEM lugs"
https://parts.olathetoyota.com/blog/trd-pro-wheels-faqs
Chip H.
Old Apr 7, 2021 | 12:19 PM
sbaradaran's Avatar
sbaradaran
Chip H.
Do you mind confirming if the Lexus GX470 lug nuts worked for the TRD Pro wheels?
Thanks.
Old Apr 7, 2021 | 02:13 PM
chiph9's Avatar
chiph9
Yes, they work fine. They add a little bit of silver to the black wheels, which is nice.
Chip H.
Old Apr 7, 2021 | 05:04 PM
NTH's Avatar
NTH
FWIW, my ‘19 Tacoma TRD Pro came from factory with silver lug nuts.
Old Apr 8, 2021 | 09:22 AM
sbaradaran's Avatar
sbaradaran
Chip H.
Thank you! I'm getting these wheels put on today. Gonna see how the silver looks. Maybe find black ones down the road.
https://photos.app.goo.gl/XB6FwP44DgFS6uzL9
sbaradaran's Avatar
sbaradaran
A little contrast seems like a good idea.
Old Apr 8, 2021 | 11:20 AM
NTH's Avatar
NTH
They do look good.
Old Apr 8, 2021 | 12:13 PM
Lexus4321's Avatar
Lexus4321
With that style of look, I would replace all the bolts with ones about 1/2-3/4" longer ones, and then use nuts.
Dorman lug studs & nuts, the gold hue ones. You just need to find the right size and splines to match, but you can start with their app guide on their site, etc. They have a XLS doc somewhere that has full listing of their studs w/ specs, so once you find a matching item in app guide (which gives size & splines) you can then seek out the longer studs. I did this to my Tacoma years ago, never once an issue.
Old Apr 9, 2021 | 06:03 PM
Jpilot's Avatar
Jpilot
I got a set of these for my new wheels and they are awesome.
Amazon Amazon
Old Apr 10, 2021 | 01:51 PM
Lexus4321's Avatar
Lexus4321
My bad, I used these wheel studs on my tacoma, and then got the nuts from Dorman. Looks super good on black rims.
Amazon Amazon
Old Apr 10, 2021 | 05:17 PM
sbaradaran's Avatar
sbaradaran
Can't seem to locate the key for the lug nuts to remove stock wheels...found out at the tire shop. Durrrr.
Where is a common place ppl store their lugnut keys in the GX? I looked in the tool box and glove box. Maybe the spare? I haven't looked there.
Old Apr 10, 2021 | 05:44 PM
chiph9's Avatar
chiph9
All the compartments. Don't forget the one in the driver's side back where the jack is.
If you can't find the key, most tire shops have ways to remove the locks. You will need to have four lugnuts ready to put on in their place.
Chip H.
Old Apr 12, 2021 | 09:11 AM
sbaradaran's Avatar
sbaradaran
Chip H.
Looked in every compartment and no luck. Les Schwab Tire Center said they could not remove the lug nuts. Apparently I have to go to a lexus dealer and have them make me a key...
