Lower Control Arm Replacement
Old Oct 13, 2020 | 09:51 AM
projectd18's Avatar
projectd18
Default Lower Control Arm Replacement
Recently got a 2007 GX470 with 97k miles, upon inspection it required lower control arm replacement. Anyone know which aftermarket lower control arm is a direct replacement? I was able to find OEM for 700 on ebay but trying to see what other alternatives is out there.
Also my mechanics suggest getting new cam bolts since he will have to cut it out due to rust. Any insight or information will be greatly appreciated.
Old Oct 13, 2020 | 10:20 AM
coolhand's Avatar
coolhand
What was the issue? Bad bushing or is it cracked?
Search the local junk yard.
Old Oct 13, 2020 | 10:40 AM
projectd18's Avatar
projectd18
rust issue on the bolt. Mechanics think the bolt is seized and is not going to be able to do alignment when I put new tires in
Old Oct 13, 2020 | 07:52 PM
Lexus4321's Avatar
Lexus4321
What is the "lower control arm"? The lower A-arm (RH# 48068-60010, LH 48069-)?
I would buy the real deal, it's a very important item, etc.
https://toyotaparts.mcgeorgetoyota.c...arm-4806860010
This one on bay is just $65, hard to believe, and I would not trust it.
https://www.ebay.com/p/230495277?iid=272714599721
Old Oct 14, 2020 | 12:13 PM
chiph9's Avatar
chiph9
Agree. If the LCA fails you could get pulled into oncoming traffic or a ditch. And the wheel + tire will cause thousands of dollars in body damage to the fender. Don't cheap out on those - the price screams "Chinesium".
Chip H.
Old Oct 17, 2020 | 04:20 PM
Lexusfam's Avatar
Lexusfam
You need a new mechanic. Not new control arms. Is it pulling ? Do the current tires have abnormal wear? Is it knocking over bumps? Soak it with PB or WD40 overnight and see if that helps. These control arms last a very long time.
Old Oct 18, 2020 | 05:01 PM
Lexus4321's Avatar
Lexus4321
I suspect it was noticed that a lot of rust in/on the lower A-arm, so it perhaps does need replacing?
Or perhaps just the bolts are rusted, so some new bushings and bolts may be all that's needed.
Pics from OP would be better here.....
AMIRZA786
Build Threads
89
Oct 12, 2023 07:08 PM
Jason12327
Sep 10, 2018 08:33 PM
AnimalB
Suspension and Brakes
Aug 8, 2012 06:56 AM
cgatch
Jun 20, 2006 12:43 PM
