2008 GX470 - P1445 error issues
Old Feb 18, 2020 | 10:29 AM
JP81's Avatar
JP81
Default 2008 GX470 - P1445 error issues
I've been having the same issue with my 2008 GX since December 2019 with the lights coming on in the dash (engine, & other lights). The code I got was P1445, which leads me to believe it is the secondary Air Injection Switching Valve bank 2. I've replaced the gas cap first, then the injection pump & after a few days the check engine & other lights came on again; then I replaced the check valves & again the lights just came on again after 4 days. I'm going to re-scan the engine again this afternoon to see what codes come up, but I suspect it will be the same one's as the previous 2 times. I'm at a loss as to what the heck is the problem. I then did some research on line & ran across this thread of information & from what I can tell the solution may be to remove the filter & add the UNI filter. Is this the long term solution or do I need to replace the UNI filter on a yearly basis by checking how it looks. How is this new UNI filter working for everyone? I"m guessing there is no warranty for my GX since it is over 10 years old. Having said that, do I need to open up the engine again to look at all the parts for damage? This is crazy. Thanks for the info.
gebo
GX - 1st Gen (2003-2009)
Dec 13, 2019 07:01 PM
RobAW
IS - 1st Gen (2001-2005)
Feb 5, 2017 10:35 AM
phoenix888
Jan 5, 2016 07:36 AM
4ksucats
RX - 1st Gen (1999-2003)
Apr 2, 2012 11:57 PM
zaccor
Sep 29, 2011 07:20 AM
