Drivers window control
Old Nov 20, 2019 | 09:39 AM
gshort's Avatar
gshort
Default Drivers window control
I know this has been discussed at length.
My drivers side window control for drivers window is blinking twice. It will only control window up when you press it for auto. Resetting it by putting it half way down, then up and hold for 3 secs, and down same thing....doesn't work.
Being that it only operates the window up when pressing for auto. is it the switch?
Old Nov 20, 2019 | 10:39 AM
captainva's Avatar
captainva
So is the window rolling back down when it goes up? Whats happening exactly?
Old Nov 20, 2019 | 12:04 PM
IanB2's Avatar
IanB2
Manually roll all the way down, and all the way back up, this resets the switch after a power interruption.
If this isn't the issue you're having, try and better explain what the problem is.
Old Nov 20, 2019 | 01:36 PM
gshort's Avatar
gshort
there was no power interruption.
the window will go all the way down and all the way back up. auto doesn't work up or down. and to get the window to go up, you have to full click the button. (which is for auto, but it stops if i let go) (half click for non-auto does nothing)
Old Nov 20, 2019 | 01:37 PM
gshort's Avatar
gshort
the typical resetting the switch procedure doesn't work.
Old Nov 22, 2019 | 02:50 PM
chiph9's Avatar
chiph9
The way the computer knows you're at the top or bottom of the track is the motor stops turning (because the window is pressing against the seal, or at the bottom of the track)
Possibilities are corrosion in the mechanism that adds friction, making the computer think it's at the end of travel (or dried-up grease).
Or a weak motor.
A new window regulator isn't too bad, around $110. But the motor is pricey .. over $400
https://www.mylparts.com/v-2004-lexu...dy--front-door
Chip H.
Old Dec 7, 2019 | 12:54 PM
gshort's Avatar
gshort
thanks chiph9 !!
AJLex19
Dec 20, 2018 06:34 AM
cooperww
Nov 10, 2018 08:16 AM
noahconti
Mar 1, 2012 02:11 PM
retired
Sep 8, 2011 06:15 PM
