Spring compressor or not!
Old Mar 26, 2019 | 05:52 AM
maddtv's Avatar
maddtv
Default Spring compressor or not!
Hey fellow gx470 owners,
I have s 2006 Lexus GX470 with over 132,000 and I know it's a matter of time before the air system craps out on me. I've purchased all parts needed for the spring conversion so I'm ready. I know some of you guys on the forum have already done it, but it was never made clear that a spring compressor is needed or not. I'll do the conversion myself if a spring compressor is not needed. Otherwise I'll have to take it to a mechanic due to safety concerns.
So the question is: Do I need a spring compressor to get it done or not?
P.S. No lift. Stock height. Thanks in advance for your valuable input, guys.
Old Mar 26, 2019 | 06:11 AM
captainva's Avatar
captainva
See post #8. You might struggle a little bit but a spring compressor shouldn't be needed. Also the amount that it would need to be compressed would be minimal if you can't get it. If you really can't get it in go rent a spring compressor at your local autoparts store. Compressing a spring only a tiny bit is not dangerous at all as long as you do it correctly. Make sure that the everything is seated very well before you compress at all
https://www.clublexus.com/forums/gx-...nversions.html
peterls
16
Oct 27, 2018 06:48 PM
jvah1980
Aug 19, 2017 07:57 PM
dganapol
Jan 4, 2016 03:32 AM
Alphaman19
Suspension and Brakes
May 13, 2015 04:47 PM
djaton
RX - 1st Gen (1999-2003)
Dec 28, 2011 01:14 PM
