Shift problems
Old Mar 4, 2019 | 04:36 PM
McPierson's Avatar
McPierson
Default Shift problems
2005 Several symptoms.
Delayed shift into drive like a one or two second maybe 4 sec hesitation has happened for three years once a month or less. I changed the fluid two years ago and that may have helped a bit.
Recently the transmission fails to shift into the next gear and sort of hangs between gears. It’s hard to replicate. So I can’t exactly say what’s happening.
The wife drives it and we don’t have any lights on. No trans fluid leaks and not strawberry milkshake either.
I just took it for a rip around the block hoping it would mess up or blow out the cobwebs from her slow footed ness.
Any advice?
thanks.
Ive asked for more information
Old Mar 5, 2019 | 02:47 PM
chiph9's Avatar
chiph9
Get the codes read using an official Toyota/Lexus code reader (because not all generic code readers will understand the transmission module's codes)
Chip H.
Old Mar 5, 2019 | 05:56 PM
McPierson's Avatar
McPierson
No CEL. Would there be codes?
Old Mar 6, 2019 | 07:19 AM
IanB2's Avatar
IanB2
There could be stored codes that don't trigger a CEL, and they could be very valuable in pointing you towards a fix. You can buy a Tech-Stream software and cable setup for cheap these days, getting it to work on Win10 is another issue though, but I've seen some that have figured it out lately.
wsrivers
Jul 30, 2017 10:02 PM
Marklopez
Jan 3, 2015 03:58 PM
kennyD
Apr 6, 2014 08:56 AM
sc400123
Oct 27, 2008 05:11 PM
Spyder78
Maintenance
Nov 9, 2006 05:11 PM
