Bulb Size Chart
Old Dec 19, 2018 | 09:54 PM
OhGreat's Avatar
OhGreat
Default Bulb Size Chart
Low Beam - H11
High Beam - 9005
Front Turn Signal - 1156A
Fog - H3
Parking Light - 194 168
Side Marker Front - 194 168
Trunk - 3175
Courtesy - 194
Dome - 3175
Glove Box - 74 37
Ash Tray - 74
Vanity Mirror - 6614 6641
Interior Door - 194
Brake light - 7443
Third Brake Light - LED
License Plate - 194 168
Reverse - 7440 7443
Side Marker Rear - 7440 7443
Tail Light - 7443
Rear Turn Signal - 7440
Running Board - 194
Tried doing a search to find a compiled sizing guide. Failed to find any full lists. Just a few with forwarded links or just a couple mentioned. If I am wrong, or missing any other bulbs please let me know so I can edit this.
Old Dec 20, 2018 | 03:10 AM
ALAN553's Avatar
ALAN553
Front turn DRL 1156A. (Amber)
Old Dec 20, 2018 | 10:17 AM
vwynn's Avatar
vwynn
https://www.clublexus.com/forums/gx-...nce-chart.html
https://www.xenondepot.com/2003-gx47...bs-s/10627.htm
This has a lot.
Old Dec 20, 2018 | 01:45 PM
chiph9's Avatar
chiph9
Sylvania also has a replacement guide:
https://www.sylvania-automotive.com/apps/vlrg-us/Vlrg/
Chip H.
Old Dec 20, 2018 | 01:46 PM
chiph9's Avatar
chiph9
I've seen some early GX's with clear 1156's for front turn/DRL -- not sure how I feel about that.
Chip H.
Old Dec 20, 2018 | 08:03 PM
ALAN553's Avatar
ALAN553
Chip H.
I think the turn signal should be amber so as to not be confused with white headlights or parking lights
Old Mar 8, 2019 | 10:26 AM
dchan865's Avatar
dchan865
Chip H.
Thanks for the link. I'll need to replace my side marker light for the 1st time. I see some people having difficulty replacing it. Just to add, from sylvania web site, there is a installation video that shows how to do it.
Old Mar 8, 2019 | 03:48 PM
chiph9's Avatar
chiph9
I'm replacing the low-beams this weekend.
I swear, the bulbs you buy in the stores are a lower quality than what comes in the car from the factory. These didn't last 2 years.
(don't forget not to touch the glass)
Chip H.
Old Mar 9, 2019 | 11:46 AM
ALAN553's Avatar
ALAN553
Chip H.
if you are choosing Higher wattage like the Sylvania’is Ultras....they have less hour life than OEM...the brighter they are, the less service life.
Old Mar 10, 2019 | 06:48 PM
RockfordRX's Avatar
RockfordRX
Unless you choose LED option. It is my understanding that upgrades your brightness and service life:
Amazon Amazon
Old Mar 11, 2019 | 03:12 PM
chiph9's Avatar
chiph9
LEDs are a valid choice for the GX because of it's projector lens.
Other, reflector-only designs, just result in glare for oncoming drivers.
I didn't buy LEDs last time because I expected the H11s to last longer. I didn't this time because I had 4 days worth of rain forecast and I needed a new bulb asap so I didn't get a ticket. Oh well.
Chip H.
Old Mar 12, 2019 | 10:26 AM
jbny's Avatar
jbny
RockfordRX - Have you tried the LED from the Link you shared? From what i see the drivers side low beam housing is very close to the battery i want to make sure the LED can fit before i go ahead and purchase it.
Please let me know.
thanks.
Old Mar 12, 2019 | 06:56 PM
RockfordRX's Avatar
RockfordRX
jbny,
I have not tried the LED conversion yet. This was a recommendation of campfire, one of the members here, so I copied his link: https://www.clublexus.com/forums/gx-...t-upgrade.html
Old Feb 1, 2021 | 07:13 AM
user 720822's Avatar
user 720822
8th Gear
Default Bulb size - THANKS!
Thank you for the bulb size list.
Old Feb 2, 2021 | 11:29 AM
Lexus4321's Avatar
Lexus4321
Isn't there a larger thread in Sticky area for bulbs?
I have the XenonDepot HID kit (with their bulbs), had it for 10+ yrs. Just last week driver bulb went pink, and then a few days later died.
Great HID kit.
Lucky for me I had an extra set of Philips HID bulbs.
Crappy part was, driver side marker in headlamp also died, could not see any ez way to get the connector off from engine bay. Figured just leave it alone until I replace the headlamp assemblies, it's getting to be that time (235kmi of roadways, etc).
singher01
Aug 26, 2011 04:33 PM
voleduy
IS - 1st Gen (2001-2005)
Oct 24, 2009 09:20 AM
Paranormal
Lighting
Oct 13, 2008 11:49 AM
TitosLexus
Aug 18, 2006 01:20 PM
