Possible Owner
Old Sep 26, 2017 | 09:12 AM
jberry's Avatar
jberry
Default Possible Owner
Hey guys. I'm considering buying a 1st gen GX470. I've been on the hunt for a few weeks and have come across a few prospects. Most of the ones in my price range have between 110k-130k miles. Any tips or warnings before I jump in? Thanks in advance.
Old Sep 26, 2017 | 09:34 AM
deeken's Avatar
deeken
Yes, there's a lot you need to look into before you make the purchase with a car that many miles.
1- Was the timing belt and water pump replaced recently? If so is there proof? If not then that's something you will need to do ASAP and it's costly.
2- Any sagging in the rear? Bumpy ride? That could mean that the rear air bags or the compressor is shot and needs to be replaced. $$$$$
3- Look for tears around the CV boots.
4- Look for coolant (and all other fluid) leaks under the car. The radiators on these cars are prone to leaking.
5- other basic things such as brake & rotor check, tires, accident report etc
With a car with 100K miles be aware that you're gonna have to do a full tune-up soon such as new plugs, transmission flush, transfer case and differential gear oil change, filters, serpentine belt, etc. You can use all of that are a bargaining chip.
Old Sep 29, 2017 | 11:15 AM
jberry's Avatar
jberry
Thanks again Deeken. This information was very helpful. I have found one with 106k miles, new waterpump/timing belt, differential oil change, fuel system cleaned, regularly maintained. I will still have a full inspection at Lexus before closing the deal. Crossing fingers
Old Sep 29, 2017 | 11:33 AM
IanB2's Avatar
IanB2
Also watch for seized front brake calipers, very common on GX470's and 4th gen 4Runners.
'03 was the only year with a trans dipstick, which some people like.
'05+ got the vvti engine with a bump in power, but also a smog pump that can fail, and a recommendation to use premium fuel (lots run regular).
If you have dreams of updating the stereo, look for a non-nav truck.
Incase you didn't already know a GX470 is mechanically the same as a 4th gen 4Runner V8 LTD. trim, right down to the airbag rear suspension (on the LTD trim only).
Old Sep 29, 2017 | 12:23 PM
jberry's Avatar
jberry
Funny, I recently passed on one that had bad brake calibers. The one I have my eyes on right now is a 2007. It looks like the 2004-2006 models have slightly better reviews than the 2007. Any specific cons with the 2007? I am more than happy with the Mark Levinson sound system but may want to add a DVD system in the back at some point.
Organized Garage Status
GX - 1st Gen (2003-2009)
Aug 14, 2016 01:49 PM
ChicagoRJ
Apr 29, 2014 12:12 PM
kaosfive5
Dec 9, 2013 05:00 AM
cfkingfish
Jul 14, 2011 11:26 AM
nmikmik
Jan 3, 2011 08:57 PM
