Ist Gen GX Suspension replacement
Old Jan 4, 2017 | 10:38 AM
sjp2113's Avatar
sjp2113
Smile Ist Gen GX Suspension replacement
I know there are lots of posts on this, they are old however and allot of parts and technology has come about,
I am ready to replace my 2008 Lexus GX suspension with an Arnott suspension replacement. 2 coils and 4 shocks, the whole deal.
Has anyone done the same?
Are you happy with the decision to do so, and would you suggest anything for a guy who is ready to take the plunge.
Appreciate it.
Scott
Old Jan 4, 2017 | 05:53 PM
new2005GX's Avatar
new2005GX
Let me know if you want all four Arnott shocks for a great price. I have all 4 plus the springs for the front. I took them off my truck after approximately 20K miles because I wanted a softer ride. These ride a bit firm which makes for great handling but depending on where you live they may be too firm. I live in the Northeast where the roads are more like off road trails lol.
Old Jan 4, 2017 | 07:14 PM
sjp2113's Avatar
sjp2113
Wow that bad hugh
So what did you go to from the Arnott?
​​​​​​​is it at least a quality part
Old Jan 5, 2017 | 05:36 AM
ArXane's Avatar
ArXane
If you decide to go with a small lift check out ironman4x4 2" lift from metal tech. I installed it on Monday and am extremely impressed. Rides way better then stock.
Old Jan 5, 2017 | 07:00 AM
sjp2113's Avatar
sjp2113
So what do you plan to do after the lift?
Old Jan 5, 2017 | 07:03 AM
sjp2113's Avatar
sjp2113
oh one more thing
​​​​​​​how do you get rid of the height warning lights that people say come up after you take out yhe adjustable shocks?
Old Jan 5, 2017 | 01:01 PM
ArXane's Avatar
ArXane
Originally Posted by sjp2113
oh one more thing
​​​​​​​I actually didn't have any warning lights? I was fully expecting to. There's is some info o. What relays/fuses to pull if it does.
Old Jan 5, 2017 | 02:04 PM
new2005GX's Avatar
new2005GX
Wow that bad hugh
The Arnotts are just Bilstein 4100s that supposedly are valved for the gx. That is debateable though as noone has been able to get a definitive answer from Arnott and most likely they are not specially valved and you pay 2x the price for a regular 4100 (i.e. a complete ripoff job).
​​​​​​​I went with Monroe quickstrut fronts and 4runner rears. Do some searching and you will find a few threads related to this setup. It is pretty good and probably closer to OEM vs the Bilsteins.
Old Jan 6, 2017 | 05:59 AM
gxman1's Avatar
gxman1
Dajavu...
We had this conversation few weeks ago. I ended up going with TOYOTA 4runner front and back OEM, and kept the spring. If I were to do it over again I would go with what new2005gx said. Only reason is you dont have to fool around with swapping spring. Check my post from last few weeks on the same subject. I like my ride quality, slightly on sport mode side. However, the truck feels in control and doesnt want to do a dance at every turn (body roll)
Old Jan 6, 2017 | 06:02 AM
gxman1's Avatar
gxman1
new2005gx,
You should of mentioned few weeks back on my thread. I would of bought it from you. I live in AZ and road are great here. I originally wanted Arnot.
Old Jan 9, 2017 | 11:27 PM
tkim415's Avatar
tkim415
I just did this and am very happy with it. Used the Arnott coil conversion kit, and went with Bilstein 5100s front and back. I also swapped the front springs (Moog) and mounts (KYB).
To get rid of the blinking ride height light, just pull the TEMS fuse, which is in the dashboard fuse box.
Old Jan 11, 2017 | 12:40 AM
jryder01's Avatar
jryder01
Default Toyota 4runner Replacement struts for GX
i have read a Ton of posts about the GX suspension which has been very helpful. My GX is an 08 with 90 k on it. Mostly city miles. Air system seem fine but I am just noticing a bit of a sloppy ride; especially in the rear when I was recently a passenger. My sense is that The struts are starting to wear and that if replace them soon I could avoid excessive wear ofvthe air system; prolong its life and enjoy a better ride now. The Toyota OEM 4 runner shocks seem to be the best route for price and a match closest to the original equipment. Should I be looking for OEM Toyota 4 runner struts that fit a 2008 4 runner? Also did I read correctly that the air in the rear and variable valve adjust ride in the front: sport / luxury will all work as they do now with Lexus struts? Thanks
mstrsltr
GX - 1st Gen (2003-2009)
45
May 17, 2021 01:07 PM
Crissann
Sep 20, 2017 11:03 AM
Goosed
Aug 4, 2017 08:32 PM
LifeEnjoyr
Aug 5, 2011 04:26 PM
cknjohnny
Jun 29, 2008 08:37 PM
