So I finally got started to do some things to my 03 GX470. In changing the lights, I pulled off housing out of the drivers side door and replaced the bulb. When I did the left front passenger side and rear drivers side - I did the same thing but didn't notice there was that little bronze clip that was on the drivers door.
Do they all have clips on the plastic housing or did i just lose them inside the door panel? I did one at night so I could have just popped off on the ground and it's lost.
any chance I can just get the clip instead of replacing the housing for 30 bucks at the dealership
Thank you sir! Will check out the link. I called the dealer and they're stating the entire lamp assembly needs to be ordered just for that small tin piece..
