Transmission Issues?
Old Dec 17, 2019 | 02:28 AM
Benjam1n's Avatar
Benjam1n
Turn on your car. Move the trans shifter from p to n. Wait 5 seconds. Slowly move 4wd shifter to hi. It grinds a little (normal) but shove it in there with some force. Put main trans shifter in p. Turn off car. Don't move 4wd shifter again and drive car normally. Good luck.
Old Dec 17, 2019 | 02:56 PM
chiph9's Avatar
chiph9
Correct.
BTW, if you leave the transfer case in N when you park the vehicle, it will likely roll away. There's a red warning light telling you not to do this, as it disconnects the wheels from the transmission (which is where the parking pawl is).
The only time you should leave the transfer case in N is when you're towing the vehicle with the wheels on the ground, like behind an RV. Something which Lexus says not to do.
Chip H.
Old Dec 17, 2019 | 04:34 PM
ALAN553's Avatar
ALAN553
Originally Posted by AlexRobles
I am not his wife. I am also having the same problem. I was able to drive with the 4wd in neutral position since I bough this car second hand. I used the 4wd in low and high for a bit and when I wanted to go back to normal driving with the 4wd in neutral position the car won't move and as the guy said when I try to put my car in parking it makes a grinding noise. Please help
car doesn’t move in N....it had to be in H
Louielace6
Aug 27, 2017 03:07 PM
Christian
Aug 22, 2017 01:17 AM
g0tem
RC - 1st Gen (2015-present)
Mar 28, 2017 05:24 AM
Gold4x4
GX - 1st Gen (2003-2009)
14
Sep 28, 2015 07:50 PM
986ci's
Feb 29, 2012 06:53 AM
