TPMS Sensor
Old Feb 12, 2014 | 03:32 AM
redrocks's Avatar
redrocks
Default TPMS Sensor
Is it possible to replace a rusty valve core on the sensor without having to replace the entire TPMS sensor?
Thanks for your inputs.
Old Feb 12, 2014 | 06:54 AM
RCsGX's Avatar
RCsGX
Yes. A rebuilt kit comes with a new valve core. They're around $5 per sensor.
Old Feb 12, 2014 | 10:43 AM
redrocks's Avatar
redrocks
Cool! Thank you for the information. Looks better than spending over $300 to replace the entire sensor.
Old Feb 12, 2014 | 12:35 PM
mrblister's Avatar
mrblister
The sensor cost is $ 52.00 per wheel at Sewel. I just bought a set of 4
Old Feb 12, 2014 | 01:14 PM
RCsGX's Avatar
RCsGX
I'm sure they're the same but Sewell lists a different part number for '06+ and they're slightly more @ $59 a piece?
Old Feb 12, 2014 | 05:34 PM
MichaelD86's Avatar
MichaelD86
When it comes to rotating the tires do the sensors have to be re calibrated or setup so that it knows which tire is where? Also is there something in the dash that will show you the tire pressure of each tire or only when its low? I have a Silverado with TPMS and I have to reset it every time I rotate the tires by letting air out util the horn honks on each corner.
Old Feb 12, 2014 | 05:42 PM
IanB2's Avatar
IanB2
It doesn't care which tire is where, simply let's you know when one or more drops below the threshold. Nothing needs to be messed with when rotating the tires.
Old Feb 12, 2014 | 05:45 PM
MichaelD86's Avatar
MichaelD86
Thanks, how do you like those Duratracs you have on yours? Ive been wanting to go a better tire. I like the Nitto Terra Grappler or the General Grabber AT2's. I have those on my truck and its a pig in the snow. I also want something that will go a few miles. How are they lasting?
Old Feb 12, 2014 | 05:47 PM
RCsGX's Avatar
RCsGX
My CTS-V was the same way. It would tell me the individual tire pressure and if you rotated the tires you had to reset them so it could recognize the new positions. Sometimes it was a pain but I liked knowing the individual tire pressure.
The GX will only come on when it falls below the preset PSI.
tucker21
May 19, 2016 05:26 PM
BieberNutz
Wheels, Tires & Brakes Forum
Jan 1, 2016 01:03 PM
jasone36
Mar 18, 2013 11:17 AM
GQis350
Aug 26, 2012 08:35 PM
swooopeno
Mar 2, 2011 08:34 AM
