HIDs
I installed a 55w 8000K HID kit on my GX470, but the amount of light coming out isn't sufficient, compared to another car i installed exactly the same kit on. I get a really nice, bright light that spreads a good distance with my other car and on the Lexus, i get dim light with some greenish tint (should be blue as it is 8000K) that doesn't light a lot of the road ahead of me.
Any ideas why that might be and what can i do to improve the amount of light and the distance it shines?
Thanks in advance.
Thanks in advance.
8K is really not all that great for Bright white light --I run 5K and its stupid bright on my GX. What other car do you have a kit on, is it a SUV, remember GX sits much higher than you car thus your lights are much closer to the road. Are both bulbs greenish tint--something doesnt sound right if they have that color tint.
Thanks in advance.
Thanks in advance.
That's the problem w/ certain kits, they're not consistent w/ what they put out. Sometimes you get what you pay for.
thank you for your replies.
both kits were brand new and was bought from the store i trust and bought before and had no issues with. they are not cheap kits you see on some sites. the other car is a sedan and with 8K on it, outputs a really bright, white with blue tint light. On GX, both sides output the same greenish dim light. I realize that since SUVs are higher, it will not be as good as the sedan's but there difference seems to be really big. I did try to reinsert the bulbs, make sure they are clean, seated correctly, etc. - nothing helped.
If both use the same bulb try switching the kit from your car to your GX and see if the color stays the same as the car. If they use different bulbs return it, get your money back then buy a reliable kit from TRS:
http://www.theretrofitsource.com/
Better yet save your money and do a retro:
Soledad
Jan 15, 2016 11:43 AM
