Problem with HIDs blinking at high speeds
Old Jan 13, 2009 | 02:13 PM
Misha98GS4's Avatar
Misha98GS4
Default Problem with HIDs blinking at high speeds
Hey guys,
I installed on my dad's car an Extreme 4300K HID kit from xenondepot. I followed the instructions posted on the website here. Everything works well except there is a slight problem. When driving at higher speeds, for example on the highway, the HIDs blink. They turn off and on right again. So people driving in front think you are signalling to them to switch lanes, and everybody keeps getting pissed off. They blink pretty frequently, about once a minute. Did anyone else run into this problem before? Thanks for any help!
Old Jan 13, 2009 | 03:10 PM
XenonDepot's Avatar
XenonDepot
Former Sponsor
Hi,
It sounds like you have a loose connection. Speed will have no effect on the HID performance.
Steve
Old Jan 13, 2009 | 09:30 PM
Booyah's Avatar
Booyah
May be the wind coming thru under the hood moving some wires around, you have something loose up under there for sure
Old Jan 14, 2009 | 09:29 AM
gsobol's Avatar
gsobol
Both of them blink or just one? Did you install both relays provided in the kit? Where are you getting your main power to the HIDs (directly from the battery?) ? Where and how did you ground the balances? Both at the same location? .... so many variables.
Old Jan 14, 2009 | 06:41 PM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
I would unplug and clean the connectors. Are the ballast mounted securely?
Old Jan 15, 2009 | 02:17 PM
Misha98GS4's Avatar
Misha98GS4
Well for some reason speed does have an effect, this only happens at high speeds. The ballasts are mounted securely. I already unplugged, cleaned, and checked all connections before. Both of the lights blinks. I installed both relays, and yes the power is coming from the battery. Balances? did you mean ballast? The ballasts were mounted at two different places, and were grounded on the inside of the engine bay on two separate places
Old Jan 15, 2009 | 09:09 PM
Booyah's Avatar
Booyah
Check your main Power line coming from your battery up to the were the main fuse is! It has to be somewhere in that I would think because Both are doing it, so somewhere its losing main power.. Check the fuse area--make sure the fuse is in Tight, maybe replace the fuse too just to make sure as it may have a weak spot somehow.
Old Jan 16, 2009 | 06:26 AM
BurgBoxstr's Avatar
BurgBoxstr
Are you 100% sure it's both lights flashing?
If it's both, then I'm 99.999% confident the issue is not w/ the HIDs themselves but with the car. Reason being: each light is 100% it's own circuit. It's a safety feature in case one side goes out. So, something affecting both equally means the cause is before their separate circuits in the system. The things they have in common are:
- main power source (your battery) - but separate leads from it - not likely cause if both are secured and have good contact
- ground (chassis) but again separate points - not likely cause either
- turn on source (low beam headlights) each is fused separately but relay is common - my guess is here as a place to start
So... unless you eliminated one of the HID's relays or +12V leads from the battery and made them common for both sides, I suspect the issue is w/ your GX's OEM lighting circuitry. I would temporarily swap back in your std halogen bulbs (disconnecting the HIDs) and see if they too flash or "pulse" at speed. Since they are halogens, I you won't see them completely turn on off, but you will see them pulse. If you do, then you need to dig in further to find out why they are "pulsing"... could be an alternator issue etc.
Start by eliminating HIDs and good luck
Old Jan 16, 2009 | 09:00 AM
Booyah's Avatar
Booyah
Thats why Im also saying check the main power source from the hot lead from the battery to the fuse before it seperates the circuits!
Old Jan 18, 2009 | 12:05 PM
Booyah's Avatar
Booyah
You get this fixed yet? What was it
Old Jan 19, 2009 | 10:16 AM
Misha98GS4's Avatar
Misha98GS4
No I didn't fix it yet. It's my dad's car, I might try it this weekend, we're just both on different schedules.
Old Feb 8, 2009 | 05:54 PM
wilwilB's Avatar
wilwilB
my car is also doing this except only the light on the passenger side blinks when the car is moving. the light on the driver side is perfect. anyone knows why?
Old Feb 9, 2009 | 04:04 PM
gsobol's Avatar
gsobol
Check your relay, power connection, ground - in that order.
aesthetics
Jan 30, 2012 10:00 AM
RyanQ
Lighting
Dec 15, 2008 08:52 PM
lexus27
Dec 29, 2005 09:35 AM
SNiiP3R
Lighting
Dec 26, 2005 09:23 AM
bsjoiner
Lighting
Sep 28, 2004 07:26 AM
