Head Unit Wiring Diagram
Old Oct 24, 2008 | 11:45 AM
mwbuck's Avatar
mwbuck
Default Head Unit Wiring Diagram
Does anyone have the wiring diagram for the head unit w/in dash cd changer on an 05? It looks like this:
I'm trying to find the 4 wires that carry L/R +/- audio from the CD player to the amp.
Old Dec 29, 2008 | 05:14 PM
mwbuck's Avatar
mwbuck
Does anyone have this info?
Old Dec 29, 2008 | 05:53 PM
BurgBoxstr's Avatar
BurgBoxstr
Someone uploaded the attached file over a year ago - I presume on the same quest you have. IIRC, it was for an '04 but not 100%. Should help you out though. Also with a good search, you should be able to find the original w/ all the details.
Good luck
Old Dec 29, 2008 | 06:02 PM
mwbuck's Avatar
mwbuck
Absolutely perfect! Even more than what I was looking for.
I've spent the last 2 months searching for that diagram on these forums with no luck. Thanks so much for your help.
Old Dec 30, 2008 | 02:14 PM
charlie@jd's Avatar
charlie@jd
cool.... i don't understand diagrams. maybe mwbuck can help me out. how does the rear entertainment system turn on? i have none navi and i replaced it with dd unit. but the rear display doesn't turn on now. dvd player has power but the lcd has no power. there's a remote turn on from the head unit. i just dunno which one. would u know?
charlie@jd's Avatar
charlie@jd
oh.. and the vss for the gps. where is it located? not the red/green from the ecu. that doesn't transmit pulse. i tried and it's not the one i'm looking for.
Old Dec 30, 2008 | 04:01 PM
NexVision's Avatar
NexVision
If your looking for the kill drive sense while moving the wire is directly at the gps unit under the passenger seat theres a thread talking about it with a picture tutorial.
Old Jan 12, 2009 | 09:33 PM
charlie@jd's Avatar
charlie@jd
no i'm talking about the wire that transmit the vehicle speed signal to the gps. i am installing an aftermarket gps and that's the one i'm missing.
C Anderson
36
Jan 5, 2019 09:52 AM
cdeptula
RX - 1st Gen (1999-2003)
Jan 21, 2010 09:14 AM
t70 supra
Sep 22, 2007 03:01 PM
Ali SC4
Feb 16, 2002 03:40 PM
