New Thump Update
Old Oct 26, 2004 | 02:01 AM
geewiss's Avatar
geewiss
Originally posted by tetra7
Okay ppl...been a while since I've thought of this topic. Can someone do a simple test for me? I need someone who has the consistent "thump" (I consider it more of a "clunk") to try this. While slowing down, please put your hand LIGHTLY on the 4x4 shifter located right of the gear selector. PLEASE DO THIS IN A SAFE MANNER & USE YOUR COMMON SENSE!
Please let me know what you feel (or don't feel). I suspect I already know what will happen. I would try this myself, but I can not replicate the "clunk" consistently. Also, please note how aggressively you are braking when you do this.
Thanks...Rob
Thats funny that you mention doing this because the very first time I complained of the thump that is what my technician did. He stated that he felt the thump there also and then he said OK, I know how to fix this.
Well three visits later and I am still having the same problem. Although not as consistant yet .
Old Oct 26, 2004 | 08:53 AM
PitBull's Avatar
PitBull
I now have 11K miles on mine and the thump has gone away. If you grease your driveline every 4-5K miles and give it time this problem will "wear in" and go away (it's called driveline wind-up, common with AWD systems, all the parts have to wear in and it needs to be lubed regularly ). Same experience with my 95 Landcruiser. I would not have some tech at the local dealer disassembling and working on my driveline, you will end up with more problems then you "thought" you started with, as some of you are now finding out. Good luck
Old Oct 26, 2004 | 09:14 AM
Randy20g's Avatar
Randy20g
The GX, LX, 4runner and LC, do not have AWD systems. They are Full time 4wd systems. The RX has AWD. The two systems are considerably different.. I have been driving AWD and 4wd systems for years. This is the first time I have ever had a "thump" situation. As for the idea or it "wearing in", I tried that with the first driveshaft. It got worse. Now with the second driveshaft, it has returned in 500 miles.
I spoke to Lexus CC today. They are aware of the issue (of course) and will be "getting back to me".
Old Oct 26, 2004 | 03:52 PM
PitBull's Avatar
PitBull
Now I'm starting to see what your problem is, since you know so much about these "AWD" "Full time 4 wheel drive" systems you should be able to figure out what needs to be done to fix your GX. Guess I'm not as smart as you but I fixed my thump. I also had the thump in a 1995 Toyota Landcruiser and did the same thing and it went away. Had 135K miles on the LC when I traded it and never had a problem. I think you already screwed up having the local Lexus shop replace your driveshaft, I think you realize that.
Old Oct 26, 2004 | 04:19 PM
Randy20g's Avatar
Randy20g
Default tone it down
#1 - I had been a Mitsubishi Technician for years. I think I know a little bit about 4wd systems.
#2 - As per the TSB from Lexus, they MUST now replace the driveshaft whenever a customer complains about the thump.
#3 - Yes, I have heard of driveline wind up, working on Monteros with 4wd systems, not on AWD.
#4 - The issue appears to be gas build up in the driveshaft, and the lack of gas release causing the driveshaft to knock back after a stop.
#5 - I cannot dictate a course of action for Lexus to follow. They are bound by the manufacturer to follow the procedures they are given. I know this red tape BS all too well.
#6 - This issue was not bothersome to me until most recently. It has not improved, but has deteriorated, and will not improve with age.
#7 - With the experience Toyota has with 4wd systems, this issue should not be present on a $53000 GX or a $66000 LX. It should not even be on a $24000 Mitsubishi.
#8 - If you thik the average owner as a "solution" wants to (has to ) take his vehicle in to be "greased" every 4000miles, I think that is pretty poor.
Lastly, dont take the argumentative approach to your posts. I sat back for the last 8 months watching the thump posts and following the cases. I did not post a thing until this week after visiting the dealer. I simply posted to relay my findings. I guess since you "see what MY problem is" then you see what EVERYONE elses problems are with this thump issue.
Old Oct 26, 2004 | 04:26 PM
PitBull's Avatar
PitBull
Randy, good luck getting your thump fixed on your full time 4 wheel drive GX470.
Old Oct 26, 2004 | 05:19 PM
Rx900's Avatar
Rx900
this hasn't answered my question if the thump can be claimed for the Lemon Law!
Old Oct 26, 2004 | 07:06 PM
tetra7's Avatar
tetra7
Hey folks..didnt mean to start a war here..but this is for my own personal knowledge. I have a working idea on whats going on..thats why i wanted that experiment.
btw, yes I am an engineer...so entertain me.
Old Oct 26, 2004 | 08:10 PM
GX470forme's Avatar
GX470forme
Why not get out your phone book or do Google search and call a local Lemon Law Attorney. They will give you a free consultation
Good Luck
Old Oct 30, 2004 | 06:32 AM
Rx900's Avatar
Rx900
oh man! two weeks later, my Gx is back in da shop! now i didn't complain about the clunk yet, but now my brakes "are falling apart!" meaning that my brake axle was leaking on one side on my 20k service, now both rear axles are leaking! what's going on?!?!??!?!??!
Old Oct 31, 2004 | 06:29 AM
Rx900's Avatar
Rx900
ok this is it. I'm really getting pissed with my dealer. any ca dealer suggestions? preferably northern ca, I know Magnussens is a good one. other suggestions??
Old Oct 31, 2004 | 11:48 AM
lexuslvr's Avatar
lexuslvr
Wink best truck I've driven
I don't understand the chatter about a thump. This truck is the best riding, driving, off road vehicle I've driven. When on the road, my friends who drive other trucks are envious. When we go off road, everyone wants to ride with us. If others are noticing what I call "sit down" when I come to a somewhat faster than usual stop, or when the a/c compressor kicks in, It's much more noticable if I am forced to use less than the best in gas. (Once had to use Arco premium....boy, what a difference in performance...yuck! My gas of choice is Chevron premium) This does not make it a bad car, it is just how it works.
My only wish is that it had more cargo room. But if that was the reason for buying a 4wd, I would drive something else.
In my opinion, this is one of the best 4wd vehicles made and I think we should remember....it's not a car, it's a 4wd truck with the comforts of a car!
(the kids and adults love the DVD!)
Old Oct 31, 2004 | 02:52 PM
Rx900's Avatar
Rx900
Default Re: best truck I've driven
yeah except our thump, vibration, creaking seat, cladding rattle, and two rear brake leaks ruin all the fun!
Old Nov 6, 2004 | 08:24 PM
Capirato's Avatar
Capirato
Default THUMP
Picked up my GX at the Lexus Service Department today. They prepared the new Drive Shaft before installing it. They followed some procedure including drilling a hole somewhere.
I could force a thump by moving the switch that raises and lowers the rear of truck. I tried the same procedure on my way home from the Service Department, but NO thump.
I never was too concerned about the thump, but since reading so much about it, I decided to have the Drive Shaft changed.
~ Cap
Old Nov 8, 2004 | 09:03 AM
super_cjc's Avatar
super_cjc
The reason that I bought the GX is mainly for its smooth and quietness. It¡¦s a humiliation when your friends are riding with you and enjoying the smoothness and quietness of the new GX and suddenly there¡¦s a big thump and everybody thought you got rear ended.
Got a new driveshaft about 3 months ago, didn't really solve the thump problem.
Now I have about 19k miles on the GX, I don't feel the thump anymore. Hope it's gone permanently.
Maybe the wear-off theory is true.
