Our GX is less than a month old. Just discovered that it has an automatic ignition. That is, you can turn the key to the start position and release; the ignition will continue to crank until the engine starts. Has anyone else discovered any other not-so-obvious feature?
Originally posted by trentpa Our GX is less than a month old. Just discovered that it has an automatic ignition. That is, you can turn the key to the start position and release; the ignition will continue to crank until the engine starts. Has anyone else discovered any other not-so-obvious feature?
I was very pleased when I found this feature... very cool
the one touch start is on the '03 also. And if you hold the MODE button down on the wheel it'll turn the radio off. You can also turn it on from there too.
We do not have the rear entertainment option. What I do for long trips is plug in our 13"TV/VCR combo into the AC outlet behind the second row and it's instant entertainment center. Record six hours of cartoon network and plug in the tape and headphones and little ones love it.
place the switch on the left mirror..when backing both mirrors drop
place the switch on the right mirror..only the right mirror drops
place it in the center...only the rear view backup cam is active
I've gotten used to that auto start with the ignition. Now when I get in my X5 I do that and it doesn't turn over. I have to keep paying attention to which car I'm in. Same with the windshield wipers. I keep waiting for the X5 to turn them on (I know, some X5's have the auto wipers, mine doesn't).
