2005 Passenger window issue
Old Jan 2, 2024 | 01:22 PM
501shane's Avatar
501shane
4th Gear
Default 2005 Passenger window issue
Front passenger window works one time and stops, unplug it and will work one time and quit. I've thrown every part at it and still doesn't work. New motor, new switch and new master drivers side switch. Is there some resistor or wiring to check? Any idea on where to go from here?
Old Jan 2, 2024 | 04:26 PM
chiph9's Avatar
chiph9
Only thing I can think of is the wiring. The usual spot for it to go bad is where it flexes at the door boot. Try opening and closing the door several times and/or squeezing the boot to see if the behavior changes.
Chip H.
Old Jan 2, 2024 | 06:45 PM
501shane's Avatar
501shane
4th Gear
Thanks for the reply. I’m gonna dig into the wiring and hope it’s an easy find.
Chip H.
Old Jan 3, 2024 | 10:16 AM
mattyg3535's Avatar
mattyg3535
Dumb question but did you disconnect the battery?
If you did you have to hold the button down for a few seconds and then up till it closes for a few seconds to reinitialize it.
I thought my window motor went. It is in the Sticky section.
If not......good luck and let us know what you figure out.
Old Jan 3, 2024 | 10:24 AM
501shane's Avatar
501shane
4th Gear
Yeah I did all the normal things. Tried just one side of the battery then both for lengthy periods. Tried to get the window to learn the end points and it never makes it. Hopefully I can find a wire or something easy but I’m stumped so far.
Old Jan 4, 2024 | 12:02 PM
501shane's Avatar
501shane
4th Gear
Short video cut to show issue
File Type: mov
Last edited by 501shane; Jan 4, 2024 at 12:17 PM. Reason: Attachment didn't show up
Old Jan 23, 2024 | 02:48 AM
Flagolfer's Avatar
Flagolfer
10th Gear
My problem started differently but ended up same/similar to your windows.
Background: Water came in inside the cabin and hazard lights coming on by itself (times varied an hour to two hours after ignition was off).
Went to a recommended electric focus mechanic and he says sunroof drain is plugged causing it overflow and caused damaged to the electrical system within the pillar.
He said the part would cost $1700 but over 4 months wait, possibly. Option was to go with a guy who specialized redoing the wire work by cleaning & rewiring individually.
This fixed the random hazard light flashing but the windows did not work together or auto-mode.
The shop says it's fusebox.
So, I am going to try find the fuse box for 2003 GX470.
To all members: Any suggestions?
Alexbenz
Jun 15, 2023 06:12 PM
RonCon
RX - 4th Gen (2016-2022)
Jun 7, 2021 02:54 PM
YZFR1
Jan 15, 2021 07:32 PM
misterlv
Jun 9, 2012 12:42 PM
Luv Da Lex
Oct 10, 2008 12:35 PM
