--Passenger front window issues---
Old Jun 15, 2023 | 10:14 AM
Alexbenz's Avatar
Alexbenz
Default --Passenger front window issues---
hey guys so all my windows work, only issue i'm having is the front passenger window from the driver's master switch rolls all the way down and all the way up. I can crack the window but from the passenger front seat the door's window switch it allows me to. Is it a programming issue or maybe the master switch has an issue? all the other 3 doors work fine.
Old Jun 15, 2023 | 10:23 AM
Bad master switch, broken wires in the door loom are the most common causes.
Old Jun 15, 2023 | 10:28 AM
Alexbenz's Avatar
Alexbenz
but if that was the case then the wndow wouldn't work. It works but not like it's suppose to which makes me think it's a programming thing.
Old Jun 15, 2023 | 10:36 AM
Your description is not clear
I can't crack the window at all but from the passenger front seat the door's window switch it allows me to.
Does the front passenger switch work?
Old Jun 15, 2023 | 04:35 PM
Alexbenz's Avatar
Alexbenz
my bad, i didn't proof read what i wrote. So it works perfectly fine from the passenger front door, from the driver's master switch it just goes all the way down and up, i'm not able to crack it little by little.
Old Jun 15, 2023 | 04:47 PM
Not even if you touch the switch for a split second?
Old Jun 15, 2023 | 06:12 PM
Alexbenz's Avatar
Alexbenz
nope, it's only like that for that one window
RonCon
RX - 4th Gen (2016-2022)
Jun 7, 2021 02:54 PM
geopig
Mar 25, 2019 04:17 AM
misterlv
Jun 9, 2012 12:42 PM
Sayuri07
RX - 1st Gen (1999-2003)
Apr 7, 2010 11:07 AM
Luv Da Lex
Oct 10, 2008 12:35 PM
