Rear control arm
So I'm wondering if anyone knows specifically which part he's referring to so I can go buy it for much cheaper.
Quick guide. We have a rear upper control arm, front upper control arm, front lower control arm no.1, and front lower control arm no.2 (castor), and rear trailing arms. In the rear you also have traction rods, and toe control rods. None of these things are adjustable from the factory in terms of putting an alignment back into specs if other parts are bad or loose.
If your rear toe is out of spec; you have to look into a few things; first your rear toe control rods might be shot. You can replace the oem part (48705-30070) with adjustable aftermarket toe rods of your choice. You can use the adjustable aftermarket IS300 toe control rods as well. If your rear upper control arms are shot or seized (48770-30052) then you should replace them if you can find them. I suppose IS300 rear upper control arms would work but no one here that I know of has tried them on their GS2.
I've only listed one side for the oem part numbers. Any other questions feel free to ask.
Part 2 is the upper control arm
Part 1 is the knuckle/hub
Part 8 is a plastic cover
Part 4 is the rear arm
Part 9 is the traction rod (can be replaced with an aftermarket adjustable one)
Part 12 is the toe control rod (can be replaced with an aftermarket adjustable one)
The sewell site is funky on cross browsers, their code is breaking because theyre adding a facebook component to their catalog, probably an adp thing.
here it is on a 2001 gs430 which will share the same parts (same pic but laid out nicer or atleast i think it is)
http://lexus.sewellparts.com/oem-cat...S430-2001.html
Therefore labor for one shouldn't be too much different from labor for both sides right?
Someone tell me i'm rite because i'm being quoted $500 labor one side and that sounds like alot
I'm looking at partsgeek website and 1 REAR SUSPENSION lower control arm is about ~$125, and Sewel's part # 48730 is $157, assuming this is the correct part in question all along.
It's also been recommended to me that I get the REAR tierods and maybe even traction bars (I'm assuming they meant the toe-in adjustment bar part #12 and traction bars part #9).
