GS430 - 2001 : Common problems?
Old Jul 26, 2010 | 11:55 PM
joomlarus's Avatar
joomlarus
Question GS430 - 2001 : Common problems?
Found a GS430, 2001 with 117k miles for a very good price. Going to check it out tomorrow.
What are the common problems that I should check for?
I thought 117k miles is nothing for a Toyota, but reading some posts here made me wonder. Is that an issue with the GS430?
( sorry haven't had time to do thorough research since this came up quickly )
Old Jul 27, 2010 | 02:35 AM
bronx99's Avatar
bronx99
mine has 112k and runs silky smooth. luv it.
had to fix the door actuators though.
Old Jul 27, 2010 | 03:50 AM
Rich23's Avatar
Rich23
What do you mean by reading "some posts"? Be a bit more specific please...
Old Jul 27, 2010 | 06:58 AM
joomlarus's Avatar
joomlarus
Thanks!
@Rich23: I searched the forum and found many posts about brakes going bad (master cylinder==expensive) and ball joints around 100k
Also a handful of posts about various check engine/sensor problems, also starting to happen even below 100k.
Idle being rough, or even stalling etc.
Alternator going bad
Reading all this made me wonder how common it really is..
Old Jul 27, 2010 | 07:21 AM
Infamous 1's Avatar
Infamous 1
Get a carfax, maintenance records, make sure the 90k service was done, and make sure ball joints & tie rods were changed.
Old Jul 27, 2010 | 07:23 AM
JiBBeL's Avatar
JiBBeL
My 01' has had the following issues after 105k miles:
Sunroof shade rattled - easy DIY fix
Glovebox rattled - easy DIY fix
Door lock actuator broke - $5 DIY fix, pain in the butt tho
AC mode servo is clicking - not yet fixed
Might have air in coolant (high pitch bubbling noise behind drivers vent)
As you can see... nothing major
Old Jul 27, 2010 | 07:26 AM
joomlarus's Avatar
joomlarus
Thaks everyone!!!!
They want 3.5k for it - which I think is too cheap. Makes me suspicious...
Old Jul 27, 2010 | 08:07 AM
jjbenzo's Avatar
jjbenzo
They are only asking $3,500 for an 01 GS430?? Wow, something has to be wrong. I wouldn't even waste my time on that car. A car like that without a salvage title and no major issues should get at least $11,000 I would think.
On a side note, these cars really are quite excellent. Do your fluid flushes like you should with any car and change out the front lower ball joints, outer tie-rods, upper control arms and timing belt around 100k. Other than that, these cars really don't have any "common" problems.
Old Jul 27, 2010 | 08:21 AM
ThomasGS4's Avatar
ThomasGS4
Run like hell away from that GS.
My 98 with 128k was 8k...
Old Jul 27, 2010 | 09:23 AM
ntwrkguy1's Avatar
ntwrkguy1
I'd be REALLY suspicious of an '01 430 for $3500.....unless it is really trashed.
Even higher-mileage 430's usually sell for at least $7500. One thing I would check on is the maintenance history. If they can't produce a maintenance history, then I'd keep looking. Money saved up front on a car like this will surely be spent on the back end.
Old Jul 27, 2010 | 09:30 AM
joomlarus's Avatar
joomlarus
It's over 1hr drive for me so I won't bother.
Thanks again all!
Old Jul 27, 2010 | 09:54 AM
GS4_Fiend's Avatar
GS4_Fiend
Sounds like the one that was posted on craigslist.
Old Jul 27, 2010 | 09:55 AM
3UZFTE's Avatar
3UZFTE
x2, 147k and almost to the tee, exact same issues, minus the coolant thing and I will add:
Wind noise - semi-easy DIY that semi-fixed any issues.
Wheel balance: It seems to plague the 2GS in general, but my car was fine when i bought it, I put on Bridgestone's, and it started to shake, and hasn't gone away since, so I've been driving on my winter Perelli's because they don't do it as much. I think it's some sick combination of aluminium steering and suspension components, as well as tires, and other factors that only seem to be present on the 2GS, more specifically my 01' GS430.
Old Dec 22, 2010 | 08:33 AM
AirRideFan's Avatar
AirRideFan
yeah, that's a scam!
'98+ GS models with the V8 engines MIGHT be one of the most reliable cars you can buy though. AMAZING BUILD QUALITY. I honesty never thought I would be "THIS" happy with my First Lexus vehicle.. My GS makes me smile more and more every day. I love it!
I didn't know the rattle in the sunroof shade was an easy DIY! That's great to know. I need to look that up on here. What all does it involve?
When mine is closed, but not "TIGHTLY" it makes a light rattling sound near the back of the car more, it seems like? Weird.. I pull it closed ALL THE WAY, and it stops, until it moves back a tiny bit again. ha
Old Dec 22, 2010 | 08:40 AM
ThomasGS4's Avatar
ThomasGS4
Uh...old thread, dude.
GLIDESUL
Jun 25, 2017 05:57 AM
gsjerk
Oct 31, 2011 08:59 AM
COOLIS
Aug 3, 2009 08:22 PM
kphu
Mar 9, 2009 02:48 PM
psing23
Suspension and Brakes
Mar 6, 2003 01:54 PM
