P430 Code
Old Nov 10, 2022 | 06:57 AM
Kybball#1's Avatar
Kybball#1
Default P430 Code
Hello all, I put a resonated Apexi mid pipe on my F about 6 weeks ago. Everything was going great and the car threw the P430 code yesterday. Where do you guy recommend I start? The O2 Sensor or somewhere else. Thanks in advance.
Old Nov 10, 2022 | 07:40 AM
Doctj's Avatar
Doctj
Do you feel any loss in power or any changes ?
Old Nov 10, 2022 | 09:25 AM
Kybball#1's Avatar
Kybball#1
No not really at all.
Old Nov 10, 2022 | 08:36 PM
1wacko's Avatar
1wacko
you need to ensure that there are no exhaust leaks in the exhaust joints, which will give you the P430 code if there is. need to check the gaskets on the exhaust and ensure they are well sealed and tight. also, you might want to check the o2 sensors, but i doubt it they are the culprits. good luck.
Old Nov 11, 2022 | 02:17 AM
designo's Avatar
designo
Check the flange connection between your xpipe and the headers.
Your installer may have slipped up or re-used an aged gasket to mate the two back again.
Old Nov 13, 2022 | 01:23 PM
Searosis's Avatar
Searosis
agreed. I have apexi resonated with toms axle back and 1 year later no hiccups
Old Nov 13, 2022 | 07:47 PM
Kybball#1's Avatar
Kybball#1
Myself and a friend put it on. He has a full lift so I know everything is tight and know that we used the new gaskets.
Old Dec 1, 2022 | 07:07 PM
cliffyv's Avatar
cliffyv
Make sure your o2 bungs have no pinholes where it's welded to the pipe. A small pinhole there will trip a code for sure. You should be able to see a hint of carbon of there is a pinhole. My rr racing midpipe needed to be re-welded due to pinholes around the bung. No more cel's after.
Old Dec 2, 2022 | 11:13 PM
designo's Avatar
designo
What causes pinholes around the bungs?
Old Dec 3, 2022 | 06:10 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Poor welding.
Old Dec 5, 2022 | 02:39 AM
cliffyv's Avatar
cliffyv
Poor welding.
What he said 👍
candrade
RX - 1st Gen (1999-2003)
Nov 2, 2022 06:27 PM
Jetmech1
Jul 7, 2021 07:14 PM
Fritz330
Jul 3, 2016 07:45 PM
imDementeD
Mar 8, 2011 01:03 PM
BostonSC4
Jun 30, 2010 04:21 PM
