Help-GSF Headlight
Old Sep 30, 2021 | 11:39 AM
Mahrez's Avatar
Mahrez
Default Help-GSF Headlight
I have issue with my headlights which i have purchased them used.
once i start the engine the headlights will turn on directly and i cant switch them off unless i stop the engine. the high beam is also not working.
in the dash board its not showing any warning lights as every thing is normal.
today i get computer report and it show this issue in the picture
any one can help what need to be done to solve
Old Sep 30, 2021 | 06:56 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Are you certain these lights are the correct lights for your car? Different markets have different lighting systems, and if the lights you bought are not for the market your car was built for, you'll likely never have them work correctly.
Old Oct 1, 2021 | 01:12 AM
Mahrez's Avatar
Mahrez
Thank you for the replay !
I got them used and the problem Lexus is not mentioning the part number on the headlight unit so we code check for which market is it.
i will attach some photo which may help to identify
Old Oct 1, 2021 | 02:04 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
My parts reference doesn't find the part numbers for the controllers anywhere globally, but it would seem they might be for Middle East market since Google shows results from China and the Middle East. Very strange I get nothing at all from the resource I use for part numbers.
Old Oct 1, 2021 | 04:04 AM
Mahrez's Avatar
Mahrez
what is the correct part number for the US specification controllers ?
because when i get those controllers i have notice that the outer sticker has different part number from the one mentioned in the controller itself and when i asked the seller he said that its the same product and its because Lexus factory has changed the batch number. i dont know really have to solve this matter
Old Oct 1, 2021 | 05:24 AM
Randy B's Avatar
Randy B
This site should assist you in finding any US Market part:
https://www.mylparts.com/
Old Oct 3, 2021 | 03:21 AM
designo's Avatar
designo
I don't think there is a difference in the lighting system between ME and the US
Sometimes part numbers supersede older numbers and that is normal.
Any issues with installation maybe?
Old Oct 3, 2021 | 11:13 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
81145-30L20 has been superceded by 81145-30L21. 81145-30L50 shows up in my parts catalog as Korea spec, and has been superceded by 81145-30L51. So, designo has it right, there isn't a difference between (actually) any of the LHD cars in the rest of the world. Something else is going on with your setup.
Old Dec 19, 2024 | 02:39 PM
LFAmonsta's Avatar
LFAmonsta
3rd Gear
Does anyone know if there is a way to disable AFS in this model? Seems like you have done some work on this truck.
Old Dec 19, 2024 | 05:38 PM
jgscott's Avatar
jgscott
The GS350 has this Module on the Drivers side floor side panel.
https://www.clublexus.com/forums/ls-...-messages.html
Someone had the problem you have in the GS350 forum. They had the 2 control units you posted connected backwards. I see a L & R on the parts. Try reversing's them if you have a RHD, or even if you do not.
Mahrez
GS F (2016-present)
Jun 13, 2022 09:05 PM
arsalanban
Sep 25, 2020 07:49 PM
LSAPontiac
IS - 1st Gen (2001-2005)
May 11, 2020 01:54 AM
AKTRYTE
Nov 27, 2017 05:53 PM
k20trick
IS F (2008-2014)
Dec 7, 2015 10:08 AM
