ASC Active Sound Control
Hey guys so i have looked through the owners manual and checked all the fuse boxes in the car, the ones in the engine bay, the ones inside the car under the dash and the one in the trunk.
And i did not find the exact fuse that could turn off the ASC so i dont have to turn it off every single time i get in the car. There was one in the engine bay that said Noise Filter but the spot was empty so it cant be that one.
Did anyone on here find it or find a way to disable the ASC????
maybe this.. I do not know if it is the same as the RCF but this is what I did...
https://www.clublexus.com/forums/rc-...ial-sound.html
You have to manually override with each startup as said and I believe you are SOL for a single fuse for so many components are intermingled in cars theses days...
there is a switch but my point is i dont want to have to keep turning it off every time i get in the car. I always go into sport mode when i get in so its active and i hate having to turn it off every time.
once I put exhaust on my RCF I couldn't hear the fake ASC anymore..
but you can always just disconnect the speaker for it, on the RCF it is on the knee panel to the right of the steering wheel, you can see a little speaker "grill" there
There is no way to disable ASC so you don't have to hit the switch. Not even in LPS using Techstream. Disconnecting the speaker is the only way to really kill it. The speaker is on the rear deck next to the subwoofer. I looked into this a while ago, but haven't done anything about it yet.
finetune00
May 20, 2012 11:39 AM
