Help with P1364 code
Old Feb 21, 2024 | 07:36 AM
ArticKnght's Avatar
ArticKnght
Default Help with P1364 code
Did a little research on line for this code but didn’t really find a definitive answer and was hoping some of you could help me out.
I recently had the ECU unlocked by VF Tuner and reinstalled it yesterday and got this code. Hoping it just needs to be taken to Tuned by Loi to get things sorted out 🤞🏻.
Thanks for your help in advance!
Old Feb 21, 2024 | 01:47 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Unplug and replug your ECM connectors. One of your cam sensors is not connected.
Old Feb 22, 2024 | 06:45 AM
ArticKnght's Avatar
ArticKnght
Thank you very much sir!!! You were 100% correct. I disconnected the battery for 10 minutes and while I was waiting I checked and the plugs in the harness and ECU. Found a couple not plugged in. Connected those and the battery, then fired up the car. Started as normal and with no code. 😮‍💨😮‍💨😮‍💨
Kaianuanu
Oct 1, 2025 04:20 AM
Nutsplats
Jun 27, 2016 07:06 PM
Tmurder
Dec 3, 2015 07:49 PM
topgun129
Jul 8, 2014 05:20 AM
Hi-psi
Mar 2, 2004 08:22 PM
