2013 Lexus GS 350 F Sport BlendMount and Mirror Tap Install
Old 06-20-14, 06:43 AM
lazerlazer
lazerlazer's Avatar
Default 2013 Lexus GS 350 F Sport BlendMount and Mirror Tap Install
Hey guys I just wanted to let you know, that I successfuly installed the mirror tap kit into our vehicles. I have a Beltronics STI Driver detector, and wanted a nice clean look / install with my radar detector. I purchased the Blendmount kit which was kinda expensive for what it is, but you get what you pay for. A nice quaility piece that mounts and adjusts nicely with a snug fit. The construction of the piece is quality. The Mirror tap install instructions are garbage and useless and I couldnt find any installation guides online that helped for our vehicle, so I took a few pics. I believe the length of my Mirror tap cord was 12" as they can be ordered in different sizes, I would NOT recommend getting less then 12" as that just barely makes the run with just a little slack. In the pictures shown below, as you can see i removed the headliner panel to access the plug. Slip the red wire (power) the the brown wire (power) to get the 12v power, then slip the black (ground) to the black wire. The picture with my fingers holding the plug is the one that I used to run the Mirror tap into. I'm very happy with the products. The only thing with installing it like this, is that the radar dector stays on even after the car is shut down, you have to manually shut the radar detector off.
Old 06-24-14, 09:44 AM
BailsVT
BailsVT's Avatar
If you grab power from the rain sensor your radar detector will cut on and off with the car.
rain sensor (white/pink/green). Ground wire (black) on mirror tap goes to (white) wire on sensor and (red) wire on mirror tap goes to (pink) wire on sensor.
The following 2 users liked this post by BailsVT:
45jimmy (06-17-20), jonathancl (07-01-17)
Old 06-24-14, 09:47 AM
lazerlazer
lazerlazer's Avatar
If your referring to one of the plugs in one of those 2 black boxes, we were only pulling 5 volts off of it, so thats why we didn't utilize that one, so thats why we went off the one we were pulling 12 volts off of.
Old 06-24-14, 10:15 AM
AL13NV8D3R
AL13NV8D3R's Avatar
I dont see any pictures?
Old 06-24-14, 01:48 PM
lazerlazer
lazerlazer's Avatar
Hmmm... the pictures pull up on my computer here at work, but dont at home, and just shows a link... wtf?
Old 06-24-14, 02:18 PM
praetor
praetor's Avatar
It's probably a permissions thing. You have to put the images into a Public folder in your Dropbox account. Unless we're logged into your Dropbox we won't be bale to see the images.
Old 06-24-14, 02:22 PM
Kingkrs
Kingkrs's Avatar
I did a hardwire install as well but used the add a circuit and ran the hardwire down to the fuse box. This way the vehicle is not altered at all and the detector powers on and off with the car.
Amazon.com: Littelfuse FHA200BP ATO Add-A-Circuit Kit: Automotive Amazon.com: Littelfuse FHA200BP ATO Add-A-Circuit Kit: Automotive
Old 08-01-14, 08:40 AM
BailsVT
BailsVT's Avatar
I didn't test the wires, just followed the steps in post #38 of this thread and everything works.
https://www.clublexus.com/forums/gs-...etector-3.html
Old 07-01-17, 11:15 AM
jonathancl
jonathancl's Avatar
Rain sensor (white/pink/green). Ground wire (black) on mirror tap goes to (white) wire on sensor and (red) wire on mirror tap goes to (pink) wire on sensor.
Used this to direct-wire a dashcam:
Rain sensor pink is +12v when the ignition is ON.
Rain sensor white is ground.
Used to connect a 12v mini usb adapter.
Thanks!
Old 07-06-17, 07:21 AM
e60bmw
e60bmw's Avatar
Have you guys tried this mount by chance?
Amazon Amazon
I really need to get my radar mounted, haven't used my V1 since I bought the car.
Old 04-30-21, 10:09 AM
tamermido1
tamermido1's Avatar
Can someone Share the instructions! Link won’t open!
Old 05-01-21, 07:26 AM
jgscott
jgscott's Avatar
Received 1,259 Likes on 1,000 Posts
https://www.amazon.com/Mirror-Mount-...words=v1+mount
I had that mount is my ES. It worked well. GS would be the same.
Old 05-03-21, 06:12 AM
tamermido1
tamermido1's Avatar
Can someone post the instructions please?
Old 05-14-21, 10:28 AM
Riven
10th Gear
Riven's Avatar
I thought I would bump this thread as I did the work yesterday, with help by searching here and a few YT video's. My car is a 2019 GS 350 F-sport. I was frustrated because the pink wire was not my rain sensor wire. Used the BlendMount and bought a Uniden R3. The other frustrating part was when I slid the cover back over the wiring area, the first time I didn't realize how tight it was and pulled the plugs for this out, wasn't happy when I had it all buttoned up and it wouldn't turn on. So had to be very careful sliding the cover back on to make sure the end didn't pull on the wiring.
Wiring
Finished install
LewisLou
06-29-23 11:57 AM
RodM10
01-16-21 07:40 PM
Sagane
02-08-16 01:42 PM
treymoczy
01-07-16 07:37 PM
automaticj
11-08-12 01:04 PM
Quick Reply: 2013 Lexus GS 350 F Sport BlendMount and Mirror Tap Install
