Remote start replacement
Old Feb 11, 2023 | 08:09 AM
jklangen99's Avatar
jklangen99
Default Remote start replacement
My remote start stopped working with Lexus dropping support for 3G I think it was. Did a search here and did not find much but would think there has been a discussion. Which after market options are people installing? I looked at Best Buy and there is a relatively inexpensive solution from Viper, the DS4VB installed for $319 that gets good reviews. I called the dealer and they recommended a local shop who quoted over $700. I did not inquire as to the brand deciding to do some shopping and researching. Appreciate comments or links to existing threads. I have a 2016 GS 350 (not Sport, not F) with everything except the heads up.
Thanks,
Jim
Old Feb 11, 2023 | 09:04 AM
byungkuk's Avatar
byungkuk
try the search function
https://letmegooglethat.com/?q=clubl...remote+starter
Old Feb 11, 2023 | 09:11 AM
jklangen99's Avatar
jklangen99
already tried the search as I mentioned. Your remote+start returned the newest in 2017. Thanks though.
Old Feb 11, 2023 | 09:20 AM
modad's Avatar
modad
https://www.12volt.solutions/product...1bb74aba&_ss=r
^^This one- works great in my '17. Had to do the install with one call to customer support. Plug and play, but a little challenge only because it's scary to remove any dash parts until you've done it once....
Old Feb 11, 2023 | 09:23 AM
jklangen99's Avatar
jklangen99
Out of stock but thanks. Looking for one with a app for the phone so I don't have to carry a separate fob as well
Old Feb 11, 2023 | 09:27 AM
modad's Avatar
modad
Standard kit with APP module shows "in stock". I made it all the way to check out with a promo code also. The only "out of stock" shows to be the long range fob (middle) option.
Old Feb 11, 2023 | 09:29 AM
jgscott's Avatar
jgscott
I would like to know whats the lastest greatest for this is also. Is there one that just still used the Factory key fob?
Old Feb 11, 2023 | 09:32 AM
modad's Avatar
modad
I have the 12 Volt Solution that just uses factory fob. There may be other options, but this works every time, easy install and has for 2 years. Good luck with your search!
Old Feb 11, 2023 | 10:48 AM
PGA71's Avatar
PGA71
Mine is factory installed using the key fob with the key sequence 3 pushes and hold to start.
I find that I need to be either line of sight or within key fob range to start.
Ideally would prefer if it was an app that I can start/activate without those conditions to provide longer range with 1 touch sequence.
Old Feb 11, 2023 | 01:57 PM
peasodos's Avatar
peasodos
I have 12voltsolutions with the app model, can start car from anywhere with internet or cell reception, comes with one year of service, $99 to extend another 3 years, and uses 4G network.
Old Feb 11, 2023 | 02:42 PM
PGA71's Avatar
PGA71
That's what I'm taking about!
Old Feb 11, 2023 | 03:22 PM
jgscott's Avatar
jgscott
That's what I was asking. One that uses the Factory Fob and a phone app.
Old Feb 11, 2023 | 04:08 PM
MX73's Avatar
MX73
MPC is another solution.
Old Feb 11, 2023 | 05:18 PM
jgscott's Avatar
jgscott
Got a link? Which is better, difference? Thanks.
Old Feb 11, 2023 | 05:19 PM
jgscott's Avatar
jgscott
