Rearview Mirror teardown
Old Feb 4, 2023 | 08:24 AM
Mangsailor's Avatar
Mangsailor
Veteran: Navy
Default Rearview Mirror teardown
Anyone have some methods on how to crack open the clamshell around the mirror? I have a couple things I'd like to do to mine:
1- Check the circuitry to find ignition power, and then use this to power the homelink board. This way the module is not always powered by the battery and would be some security for others that park their cars outside their homes.
2- I'm going to put some window tint over the sunlight sensor, this will help the dimming function to be less sensitive to overhead streetlights when driving at night. At the moment it keeps turning off in certain places I frequent. Idiots with high beams on all the time shine right back even though it's "dark" out. (I've got a 20% sample taped over it at the moment and will be testing this tonight. I also have a 5% piece that I'll double over if 20 is too much)
Old Feb 4, 2023 | 09:29 AM
909's Avatar
909
Interested as well. Been using the same JDM Broadway 400mm rearview mirror for years and want to trick the mirror to stay on while the car is on.
Old Feb 5, 2023 | 02:36 PM
EAST's Avatar
EAST
Not quite the reply you're looking for, but have you thought of maybe unpinning/cutting the 12v constant wire, and adding a jumper from the 12v switched wire/pin over to the "12v constant" pin. Seems like that would give you a similar end result for the first item, though that doesn't help with the second item.
That's assuming pinout is similar to what is mentioned here.
https://www.clublexus.com/forums/gs-...tallation.html
Old Feb 5, 2023 | 03:04 PM
peasodos's Avatar
peasodos
I took one apart before. Just used plastic razor blades, insert under the edge of the joint and worked my way around the mirror, the two parts are clipped together.
Old Feb 5, 2023 | 05:02 PM
Mangsailor's Avatar
Mangsailor
Veteran: Navy
OK, then I'll give that a shot some time. I'd rather not bugger up or break it obviously. Any heads-up is helpful.
The issue is that homelink requires in most other models constant 12v for memory, 12v switched for the enable, and a ground. If I pull the constant 12v, I may lose presets. So that's why I want to get to the board inside and check to see what I can work with there. But thanks for the suggestion.
Old Feb 15, 2023 | 12:34 PM
Mangsailor's Avatar
Mangsailor
Veteran: Navy
So, I'll say something around 10-20% tint on the light sensor is what I prefer to get the mirror to dim when I want. Heres some shots from the evening twilight yesterday. The darker one I was facing away from the sun set. The lighter was when I faced towards the sunset, but had a fool with his brights on.
Later in the evening while downtown the rearview stayed tinted the whole time, even with the streetlights on us. It was perfect. In the mid-day sun or when overcast it's still enough light to have unshaded mirrors.
Very happy with this, but I want to apply the tint on the sensor directly and have it stay there. When I open the mirror up (eventually) I'll update this.
SummerRain
Jul 29, 2015 01:35 PM
HiggsBosun
RX - 3rd Gen (2010-2015)
May 24, 2015 07:29 AM
donhrec
Jan 15, 2015 01:56 PM
crwmlw
Nov 9, 2014 12:32 AM
cheetah102
Sep 18, 2003 02:29 PM
