Help with Paddle Shifters/Manual Mode
I was wondering if anyone had any tips/guidance on using the manual mode in the GS. My GS is the 6 speed. I know how to drive stick, but I dare not mess with the "manual mode" in my Infiniti and now my Lexus. I've read a few old IS threads and watched some videos online, and they weren't much help. I'm so used to having to clutch in and out and taking my foot off the gas and such, but how do you properly use manual mode in our cars. I wanna try to have some fun with it once in a while. I'm afraid to mess up the engine/transmission if I were to upshift and downshift wrong. Do I take my foot off the gas when I upshift then put my foot back on it? And same thing when down shifting, do I need to take my foot off the gas?
Nothing to be worried about. Enjoy your Lex!
initial (05-02-22)
You'll figure it out if you'll just try it. Forget about lifting off the gas when shifting. It's an automatic transmission in which you can shift manually, that's all! It's foolproof. You can't over rev the engine because it will upshift automatically even in manual mode. You can't over rev the engine by downshifting to a [too] lower gear.
initial (05-02-22)
I read that when you slow down it'll automatically downshift for me. Should I even bother downshifting when slowing down or should I just let the car do it for me?
It all depends. If you're coming to a red light, the car will automatically downshift to 1st when you fully stop. If you're entering a corner and want max exit speed, you'll want to downshift manually to your desired gear, because the GS will hold the highest gear possible for as long as possible for fuel economy.
Paddle shifters on these transmissions with torque converters are not the same as a three pedal experience where you control torque.
DSG’s are more fun but they are not smooth. I have a third car that is stick and never found the joy others do with paddle shifters.
Paddle shifters or not, I only use manual mode on auto trans cars in the mountains if im dialed in to driving and also want to save my brakes some.
So, you want to use your paddles effectively?
Find your favorite twisty road.
1. Rotate the drive mode selector to Sport S or S+
2. Slide the shifter from D to M.
3. Mat the throttle.
4. Completely disregard the upshift paddle. The car will upshift automatically for you before redline. You can never hit the rev limiter in gear.
5. As you approach a corner, brake aggressively and use the downshift paddle. The car will rev-match automatically for each downshift. If you have a 6 speed, you will likely only be shuffling between 2nd and 3rd on any given backroad.
There is no need to lift off the throttle for upshifts or downshifts.
The paddles are completely useless on the highway or in normal driving. If you are below 3500rpm, the paddles transmit the shift command by carrier pigeon, and the rev-match tune leaves a lot to be desired (it feels like someone first learning how to heel-toe, always comes up 2-300 rpm too short, making the car lurch slightly).
If you're used to driving a stick - especially in a sporty car - you'll be let down by the paddle shifter experience in the GS. It just doesn't compare to the experience of 3 pedal driving when it comes to controlling the engine. It is useful when you want a particular response because you don't have to use your foot to try to make the car do what you want.
If you've got your foot in it, the paddles do respond pretty fast, but it still has a very artificial feel. I haven't used paddles much except for in this car, so I don't know if other cars "rev match" better or worse than the GS.
I would sign up for a manual if it were available (and free) LOL. Hard to find much to complain about the GS though it has such a great balance between comfort and sportiness overall.
Other than CVT most modern cars let you have ability to change gears if not via paddles.
My 2020 AWD with 6 spd give me little to complain about. Its an auto with Torque converter and does its job well.
All I ask is it be reliable.
Love the commercials of drivers hitting something akin to downshifting.
Back on task, OP asked for help, not opinions. Sorry to go off that request. You can’t really hurt the car as discussed. It won’t let you.
