Grom vline2
Old Dec 14, 2021 | 07:50 AM
Kingmatt24's Avatar
Kingmatt24
Yeah that’s weird. I would contact grom on Instagram or give them a call and they should help you
Old Dec 14, 2021 | 09:07 AM
BMGS's Avatar
BMGS
Originally Posted by Kingmatt24
good idea. For the button, does your phone still have to be connect to BT even though you’re on AUX mode?
Yes, the button connects by Bluetooth directly to phone but it shouldn't matter if the phone is connected to the car.
Old Dec 14, 2021 | 01:55 PM
basic96's Avatar
basic96
hard to explain over text. If you’re already in CarPlay when you go into AUX, then go to the Home Screen of CarPlay to go back to GROM’s interface. Should be a grom logo for one of the apps. Then once on GROM’s interface look around the home pages until you find something and it should say “factory UI” or something.
thanks!!! Tool couple of tries but i got it working and is as good as it was.
Old Dec 20, 2021 | 01:19 AM
OUT FOX EM's Avatar
OUT FOX EM
Originally Posted by basic96
and any idea why i cant fine netflix on the play store? I find everything else but not netflix🧐
I had to sideload an older version of Netflix (check out apkmirror.com), but it works fine and have been using that version for more than 2 years without any issue.
I don't remember the one I installed but just keep trying them until you find one that works.
Old Dec 25, 2021 | 08:59 PM
ruben58's Avatar
ruben58
Hi,
not exact topic ,
but anybody knows how to reset the VLine car play from the menu,
the unit froze an I had to disconnect the cable in the back to reset it,
got a be a better way.....
Old Dec 27, 2021 | 01:23 AM
OUT FOX EM's Avatar
OUT FOX EM
Originally Posted by ruben58
Hi,
not exact topic ,
Not really another way. Just make sure your software and firmware are both up to date. I haven't had to hard reset mine like that in nearly a year, and it has been very stable. Even still it is recommended to install it somewhere with somewhat easy access as the unit may need to be reset occasionally. Unplugging it is the only way to do so when it's completely frozen like that.
Old Dec 27, 2021 | 03:52 PM
ruben58's Avatar
ruben58
Thanks ,
also been recommended to disconnect system Bluetooth and just keep VLINE2 bluetooth,
so far 4 days with no issues
Old Dec 29, 2021 | 12:57 AM
OUT FOX EM's Avatar
OUT FOX EM
Thanks ,
Yes, absolutely. Unpairing my phone from the stock Bluetooth system fixed many issues.
Oct 18, 2021 06:07 PM
abapper
Oct 12, 2021 12:33 PM
virtual
50
Aug 21, 2021 11:39 AM
Dmeadow
May 19, 2017 01:40 PM
mjeds
RC F (2015-present)
12
Nov 11, 2015 05:05 PM
