Grom vline2
Grom vline2
Hello. I just installee grom vl2 and have 3 issues. Wondering if someone else had them too.
1) mouse pad not working good sometimes. It goes everywhere and impossible to write something
2) when i start the car and original menu starts blinking every 1-2 seconds but when i go on v line and back to org menu it stops blinking.
3) mark levinson system sounds worse with grom, tried with spotify and grom bluetooth and it does not sound as good as org bluetooth of the car. Any help?
and any idea why i cant fine netflix on the play store? I find everything else but not netflix🧐
After I changed the settings, I found that the music quality was actually better than when it was played through the factory BT audio mode
how do i change aux settings? Do i do this on vline or the factory side?
I really miss using the AUX input but not being able to replay, move onto next track, etc became a deal breaker sadly
it’s been a long time since I’ve had VLine but I remember on the VLine home screen on the 2nd or 3rd page there was a row/icon with a couple dots that took you to factory UI. Then once you get in factory UI it should be easy
hmm cant seem to find the icon, what is this UI
hard to explain over text. If you’re already in CarPlay when you go into AUX, then go to the Home Screen of CarPlay to go back to GROM’s interface. Should be a grom logo for one of the apps. Then once on GROM’s interface look around the home pages until you find something and it should say “factory UI” or something.
good idea. For the button, does your phone still have to be connect to BT even though you’re on AUX mode?
