Flat Tire
Old Sep 9, 2021 | 10:09 PM
GSJ350's Avatar
GSJ350
Originally Posted by lexo98
Not trying to bash at all fellas just trying to pass on some education. If the plug wouldn’t have been the first choice then the info isn’t correct. May never cause an issue and I hope that it never does. I understand your view as a 10 year Tire Tech, but this is straight from the Discount Tire / America’s Tire website https://www.americastire.com/learn/t...storeCode=2046
Not sure what there is to bash... Also, not sure what education your trying to pass on either. Just because a plug wouldn't be my first choice doesn't mean it's not a viable solution. The plug in question here is not a dangerous option, but an option a mechanical engineer would call "Good Enough". Good enough in the since that if anything was to happen at all from using one would be a super slow leak but not at all a massive tire explosion and catastrophe like you might be thinking. One thing that wasn't said or shown in that discount tire 2 paragraph guideline, is that before a patch/plug can be installed there are 4 procedure's to prepare the tire for the patch/plug. One of those is to use a pneumatic reamer to clear the hole as well as make it to a certain diameter for the plug to work as it should. This usually causes breaks in the steel belts but acceptable under tire manufacturers repair guidelines. Example: Nylon rope has hundreds if not thousands of single strands that make one rope. If 5-10 break, this doesn't cause the rope to break or even lose any strength at all. Writing all this has "Tire"d me out so....I'm out.
jrobe
RX - 4th Gen (2016-2022)
25
Jan 10, 2022 09:04 AM
go3Ds
30
Apr 11, 2021 08:04 PM
OldLs400
IS C
Feb 4, 2019 10:54 AM
RshaoKh
RC F (2015-present)
Oct 26, 2018 08:35 AM
SRC350F
RC - 1st Gen (2015-present)
Sep 24, 2018 08:03 PM
