Techstream for 2013 GS350
Old Apr 24, 2021 | 02:25 PM
Neophyte2b's Avatar
Neophyte2b
Default Techstream for 2013 GS350
Will this work to program a new key fob for my 2013 GS 350?
Techstream
Also, what cable would I need?
Thanks
Old Apr 24, 2021 | 03:14 PM
00goobs's Avatar
00goobs
Techstream
Thanks
Yes, I am using a Tactrix Openport 2 cable. There are less expensive alternatives.
Old Apr 24, 2021 | 09:12 PM
Neophyte2b's Avatar
Neophyte2b
@00goobs Thanks!
Old Apr 25, 2021 | 12:06 AM
00goobs's Avatar
00goobs
If you were in Houston, you can copy my files....
Old Apr 27, 2021 | 09:15 PM
Neophyte2b's Avatar
Neophyte2b
If I already have an OBD2 that connects to my laptop, would I still need to purchase another cable to use Techstream?
Old Apr 28, 2021 | 05:57 AM
MX73's Avatar
MX73
Is it a generic OBD2 cable or one made for Techstream? If it's a generic OBD2 scan cable, no, it won't work.
Old Apr 29, 2021 | 05:51 AM
Neophyte2b's Avatar
Neophyte2b
Generic. Thanks.
Old Jun 18, 2021 | 05:03 PM
peteharvey's Avatar
peteharvey
Does anyone know which is the best version of Toyota Techstream for a 2015 GS350?
Apparently using too old a version is not good, but using too recent a version is not good either, because very new versions have had some features removed to bring consumers back to the dealers.
Also does anyone know what is the advantage of these latest Global Techstream Solutions Version 16's with the Vehicle Interface Module black box?
Professional for Toyota OTC IT3 Global Techstream GTS VIM V16.00.017 Global | eBay
The seller only has a 91% rating?
Old Jun 19, 2021 | 01:17 PM
dkraines's Avatar
dkraines
Not familiar with what you are showing, but I'll share what works for me. I use a MINI VCI J2535 cable. I originally bought one of these cables off Amazon, Prime option, received in 2 days. However the firmware was 1.4.1, which doesn't support the live data feed from the ECU for the 4th gen GS, I think everything else worked, but there were occasional errors. I bought the cable for live data mainly, and was not happy, I found out Googling that you need 2.0.4 firmware to get live data on the newer Lexus's. I couldn't find one on Amazon where 2.0.4 was explicitly called out. I was able to find the 2.0.4 firmware cables on Aliexpress, took almost 3 weeks to get the one I chose.
Also, as you state about features, I found v16 Techstream doesn't have the ability to customize settings on my 2013, I think they removed functionality, maybe to force you to go to the dealer. I'm using a version 12 of Techstream, which does have the customize settings button. V12 of Techstream was released on 2017, so it would probably be fine with your 2015 GS.
So, I'm pretty happy now, I'm getting all the functionality I need.
This is the cable that worked for me: Link
This cable is a clone based on a product offering from DarkHorse, and that company is apparently long gone, and driver they released for the cable is 32 bit. I have an old Windows XP laptop (32 bit OS), it worked without issue for me. I think there's a way to get this specific cable to work on the Windows 10 64 bit OS, but apparently it's a hassle. If you're tech savvy and research, maybe you can figure this out.
Good luck.
initial
Dec 21, 2023 06:51 PM
go111ld
Apr 7, 2020 11:42 PM
FI4runner
Aug 26, 2018 09:25 AM
manolo87
Aug 13, 2012 11:31 PM
DRLC6
Aug 20, 2010 09:15 AM
