AWD Tire Question
Old Oct 6, 2020 | 08:22 AM
MarxonCap's Avatar
MarxonCap
Originally Posted by AJLex19
If you have 19" OEM wheels (F-Sport AWD) - stock tires are 235/40/19 ... upsizing to 245 width gives you more options/choices and no adverse affects.
He mentioned he has 18" OEM wheels (non F Sport AWD)- stock tires are235/45/18..upsizing to slighter wider 245 gives you more tire options and no adverse affects either.
Keeping the height/profile the same in this case at 45 ensures the lowest possible difference in rolling diameter...Helpful tool: https://www.1010tires.com/Tools/Tire...ismetric=False
@MGs350 Pros and Cons: Wider tires give you more tire on the pavement thus better grip for handling/acceleration...but at the expense of a little bit of braking disadvantage and snow/sleet disadvantage. Narrower tires (215/225 wideth) are safer in inclement weather but don't grip as well as wider tires.
Usually upsizing or downsizing helps when selecting tires when it comes time to replace them, especially if you are having a hard time finding all 4 preferred tires in the stock width - upsizing just a touch gets you the same tires all around and often at a cheaper price (i've seen 245 tires cheaper than 235 in many instances!)
This was really insightful AJLEX thank you for the input. I'll keep this in mind. Yes @MGs350 car came with 235/45/18.
Old Oct 6, 2020 | 08:52 AM
jonathancl's Avatar
jonathancl
Originally Posted by MGs350
What are the advantages or disadvantages for going up a size like this? Would this be a noticeable difference in handling and ride quality also?
Going from 235/45R18 to 245/45R18 increases the sidewall thickness and width by 4.3%.
The trade is an increase in comfort for a minor decrease in handling.
Most folks are not generally pushing the limits of this car as a daily driver, so comfort is generally more important than handling.
The other popular change among those seeking comfort is GT tires instead of high performance. With them, you get longer tread life and greater comfort at the expense of grip.
I have not seen anyone report fitment issues going from 235 to 245, and it's my plan to make that change next time I replace tires.
RageRacerM
Suspension and Brakes
Oct 2, 2020 08:50 AM
loftus112
Feb 28, 2020 11:40 AM
raptor22
Oct 6, 2010 11:41 AM
Isblue
Jul 31, 2009 12:04 PM
ilmilktea
Wheels, Tires & Brakes Forum
Nov 15, 2008 04:11 PM
