all same size wheels
Old Aug 4, 2020 | 08:37 AM
dadleXus1's Avatar
dadleXus1
Default all same size wheels
hey all
i got a 2017 lexus gs 350 f sport RWD , i wanna upgrade my rims to aftermarket one , but i wanna get all same size so i can rotate the tires , i was thinking rohana rc10 19x9 all around , do any members here got the same set up on the same car , whats the fitments any spacer ? since i dont know too much about offset or anything in that natural , i really want a set up that no spacer needs can someone give me some 2cents
thanks all
Old Aug 4, 2020 | 12:41 PM
AJLex19's Avatar
AJLex19
19x9.5 will likely be too wide up front and you might rub. Most members have done 19x8.5, 19x9 or 20x9 up front without any issues. According to some sites i'm seeing, the Rohana RC10's DO NOT come in a 19x9 size (https://www.getyourwheels.com/view-w...10-matte-black)
Rohana RC10 combinations that would work to have a square setup:
19x8.5 all around with a 35mm or 40mm Offset
20x9 all around with a 35mm or 40mm Offset
Or you could do:
Front: 19x8.5 with 35mm or 40mm Offset
Rear: 19x9.5 with 40mm Offset
Bolt pattern on our wheels is 5x114.3.
Old Aug 4, 2020 | 04:26 PM
dadleXus1's Avatar
dadleXus1
Thank you for the reply ..ill probably gonna do 19x9 so i guess rohana is out of the list . Any brand of rims u recommend 19x9 and with 35mm or 40mm offset do i needs any spacer cause i dont really like to run with any of them just straight rims to the car with hub rings.
Old Aug 4, 2020 | 05:46 PM
MBradshaw's Avatar
MBradshaw
Specific brands are a personal choice, so it's hard to give you a recommendation. You also don't mention much about budget, since how much you want to spend is also a major factor. There are literally TONS of options/colors/finishes to choose from as well.
My suggestion is to browse around, looking for the 19X9s with an offset between 35 and 40mm. As long as you stay within those specs, you shouldn't need a spacer.
Old Aug 4, 2020 | 06:37 PM
AJLex19's Avatar
AJLex19
Its difficult to find 19x9 aftermarket that fit within spec without the need for spacers. You might need to compromise and go 19x8.5 all around. Niche makes some nice wheels that fall within the specs (http://www.nicheroadwheels.com/wheel...hID=218&lugs=5). Other popular wheel brands on the GS are Vossen and Velgen.
Its an older wheel but these are OEM Lexus Forged Alloy wheels where you can opt to get four 19x9 wheels:
https://www.ebay.com/itm/Lexus-19-St...-/113300832848
This is the newer OEM Lexus Forged Alloy wheels:
https://www.clublexus.com/forums/gs-...ed-alloys.html
Old Aug 4, 2020 | 06:43 PM
dadleXus1's Avatar
dadleXus1
Thank you!
Old Aug 4, 2020 | 06:45 PM
initial's Avatar
initial
Honestly, you DON'T HAVE to run spacers if you run a square setup. But imo, I would run spacers so it doesn't look like you're running reverse stagger because the rears would sit in further than the fronts. It's not required, but it just looks better. Vossen is a brand you can go for since you can get the same size wheels all around and have different offsets.
Old Aug 4, 2020 | 07:19 PM
dadleXus1's Avatar
dadleXus1
If u do run the same set up which size of the spacer would u do ?!
Old Aug 4, 2020 | 07:29 PM
dadleXus1's Avatar
dadleXus1
The reason i wanna do the square set up because this is my daily 75+miles pre day and im trying to stay Away from the spacer because i heard it make the car vibrate and not a good idea when u go high speed with spacer ... honestly idk never owned any car with the spacer 🤣
initial's Avatar
initial
I'd say a 10 or 15mm spacer. That's all you need
Old Aug 4, 2020 | 07:30 PM
initial's Avatar
initial
I've never had problems with spacers. as long as everything's tightened down correctly and you run hubcentric spacers, you'll be fine.
Old Aug 4, 2020 | 07:56 PM
gdog5149's Avatar
gdog5149
Just do 19x8.5 like I did....
G
Old Aug 5, 2020 | 08:23 AM
dadleXus1's Avatar
dadleXus1
G
Is your AWD or rwd? Look nice
Old Aug 5, 2020 | 09:56 AM
gdog5149's Avatar
gdog5149
Awd.......
G
Old Aug 5, 2020 | 01:18 PM
dadleXus1's Avatar
dadleXus1
Awd.......
G
Awww AWD is already stock square set up ..
tcal0
Mar 16, 2020 12:13 PM
silvaIS
Oct 26, 2014 08:34 PM
sojah
Jan 17, 2011 03:36 PM
ZPEED
Apr 29, 2010 09:18 PM
hollywoods
Sep 22, 2009 05:05 AM
