DIY: Mark Levinson Speaker Upgrade
Old 08-05-20, 08:43 AM
  #31
Mewannalex
Mewannalex's Avatar
ay
The sub I purchased did not fit, I had to bent the edges for it to fit. I cut it in 1'' sections so it'll bend down.
I had to spliced it and use wire nuts, it's not the cleanest, but it works.
It's not the best sub, but it's definitely better than what was there. smdh.
I still can't believe the crappy speakers from the ML system.
I put some lower grade Focals, not the 1k joints.
Again, this is an upgrade on a budget, I plan to replace the rear doors with some lower end Focals and the dash speakers. I think that would suffice me. I purchased all my stuff from Crutchfield, can't beat them, they include the brackets and the connectors for our cars.
MOB561 (08-27-20)
Old 08-05-20, 09:23 AM
  #32
DaSyce
DaSyce's Avatar
I would be concerned with Ohms. I was under the impression that the factory amplifier is 8 ohms, where most aftermarket speakers are 4 ohms.
The following 2 users liked this post by DaSyce:
Mewannalex (08-05-20), MOB561 (08-27-20)
Old 08-05-20, 11:14 AM
  #33
Mewannalex
Mewannalex's Avatar
I believe if you wire it up in series the 4 ohms DVC it will equal 8 ohms. Someone with more knowledge can chime in. 👍
Old 08-05-20, 12:03 PM
  #34
pd7702
pd7702's Avatar
Rear woofer is 5.8ohms (ML) per this diagram:
https://www.clublexus.com/forums/gs-...ml#post7734553
Old 08-05-20, 12:11 PM
  #35
peasodos
peasodos's Avatar
Received 2,227 Likes on 1,450 Posts
The high end speakers like the Focals I linked are 2 ohm’s. I plan on getting the same speakers because of the two members who installed it in the GSF had great results and the audio shops they went to recommended.
Old 08-05-20, 12:19 PM
  #36
peasodos
peasodos's Avatar
Originally Posted by Mewannalex
ay
what size and model sub did you get for the rear deck?
Old 08-05-20, 12:30 PM
  #37
thisguy_06
thisguy_06's Avatar
Heads up, the tweeter adapter bracket in OP's first post are too small.
The adapters are an inch shy, overall, to the mounting points. I have a picture comparing the adapter to the speaker (if i can figure out how to post).
Old 08-05-20, 01:53 PM
  #38
Mewannalex
Mewannalex's Avatar
8 inch Kicker 44CWCD84. Another member mention that the deck speaker is 5.6 ohms. I wired it for 8 ohms and I find to be sufficient for my liking, I just got the itch and I just ordered the center dash and the rear speakers. I think 🤔 that would be enough for me.
Old 08-05-20, 02:09 PM
  #39
peasodos
peasodos's Avatar
So your basically changing all the speakers except for the two tweeters in the rear deck?
Crutchfield only has 3 8” free air subwoofers, the others are meant to be installed in an enclosure. Not sure how much that matters.
MOB561 (08-27-20)
Old 08-05-20, 02:49 PM
  #40
Mewannalex
Mewannalex's Avatar
Yes, that’s correct. I think that will be enough for me.
Old 08-07-20, 08:24 AM
  #41
Mewannalex
Mewannalex's Avatar
Crappy corner dash speakers. smdh
Crappy ML rear doors, I replaced them with some kickers 6.5 and the corner dash as well and the difference is significant.
Old 08-07-20, 09:08 AM
  #42
peasodos
peasodos's Avatar
When you can take off the screws on the ML rear door speakers so we can see the magnet on the back side with the cover off.
Old 08-07-20, 09:35 AM
  #43
Gr8
Gr8's Avatar
Wow... If Toyota/Lexus used these sort of speakers for "High-end" ML system, wonder what they used for the base audio? Kellogg's Cornflakes boxes?! I think I have a weekend project waiting for me now. 😊
MOB561 (08-27-20)
Old 08-07-20, 09:38 AM
  #44
peasodos
peasodos's Avatar
This is the non-mark levinson rear door speakers, pics from eBay:
Old 08-07-20, 09:50 AM
  #45
thisguy_06
thisguy_06's Avatar
I will be replacing those corner speakers with these today.
https://www.crutchfield.com/p_108R30...F-3032cfx.html
I'm having a really difficult time trying to get the cover to the center speaker off, but once i can get to it, i'll be replacing that one too.
Quick Reply: DIY: Mark Levinson Speaker Upgrade
