DIY: Mark Levinson Speaker Upgrade
#46
I will be replacing those corner speakers with these today.
https://www.crutchfield.com/p_108R30...F-3032cfx.html
I'm having a really difficult time trying to get the cover to the center speaker off, but once i can get to it, i'll be replacing that one too.
In my First post thats were I would install the focal tweeters.
#47
The non-ML seem to have better cone material than the ML system. Thats.... Interesting. Though the magnet is about 25% bigger than my 2015 Prius OEM speakers. 😆
2015 Prius OEM on the left, Pioneer on the right.
#48
At least Lexus/Toyota is not using 6x9 cardboard speakers in the front of ML system. The non-ML are 6.5" but since the gap is the same, I have an option to upgrade to 6x9.
Front Right Speaker.
Im2bz2p345 (08-08-20)
#49
#50
ML speakers are not made to look expensive. They are built to spec. The doors are not full range. Replacing them with full range speaker won’t yield full range results. An audio installer of course will sell you something better or have you believe it. Bigger magnets must be better, right?
IM not here to tell you spending 2 grand is a waste and that the sound can’t be improved. Its also subjective. Just like we justify the 0-60 mph times given the car is naturally aspirated and reliable. THe midrange door speakers are designed to the ML spec that the crossovers will feed it.
When the audio engineers do their thing they are tuning the system to a desired result with a likely effect to flatten out the bass curve and equalize everything that hits the ear at the same time. We prefer more bass, we turn it up. We all like different sounds so it’s impossible to please all and if we like more modern tracks with deep bass we get more subs put in and there goes the refinement. Then we need more high end, and so forth......
After market tuners will show us the pretty speakers and sell how crappy and cheap our expensive cars speakers and get you mad. We love our cars and want all the best parts so why different. My point is with money you can improve everything. In a 17 speaker set up with ohm specs when replace it your possibly over buying given the crossover spec or messing the balance which will likely result in keep replacing them all.
Nothing wrong with having fun and trying to improve everything. Just understand the ML designers put that speaker there by spec, not magnet ounces or the pretty frame.
I did a mod the other day. I Lowered my Treble from half down one and increased mid and bass by one. Let it sit a day or two. To my preference it creates a more mid bass punch by those ****ty doors which is more audible. The sub is there to compliment that lower end. With a high quality Tidal feed on some Skip Marley tracks I was listening to the bass response was nice “To me”.
The following 4 users liked this post by Nalod:
#51
So I spent $1200 on Focal speakers for the front and rear. Got them
used on eBay. Retail it’s $1800.
for the rear door tweeter I cut apart the oem tweeter and retrofitted the focal tweeter into the mount using 3m vhb tape, looks factory.
More work/updates to comes.
pd7702 (08-09-20)
#52
This is how I retrofit the rear door tweeters.
Cut off the factory tweeter off the mount with hack saw.
Remove the cover/grill on the focal tweeter.
Put 3m vhb tape.
Stick on the focal tweeter.
Pop off the foam surround from the factory tweeter.
Break off the extra plastic with pliers.
Put vhb tape and stick it on the edge of the tweeter. Two complete tweeters for the rear doors.
Last step is to solder the connections to retain the oem plug, the oem tweeter has plus and minus so I wired accordingly. Not the prettiest but solid connections were made.
Put 3m vhb tape.
The following 3 users liked this post by peasodos:
#57
All the speakers are prepped and ready to swap in. I used nvx silicone speaker baffles to protect the front speakers from water.
Silicone baffle, back side is open.
I made my own front tweeter mounts using some plastic flooring. A drill, A hack saw, and a hole saw.
The following 2 users liked this post by peasodos:
jdpdata (08-12-20),
thisguy_06 (09-02-20)
#58
i couldn’t remove the cover either, I tried to pry it a little bit, but I felt I was going to damage the surface and stop. So I put the speakers on the corner dash. I feel que I upgraded the majority of the speakers And I like how it sounds on a budget. Next will be an amp if the ML goes bad.
#59
So, you put those bad *** speakers with the ML amp and it moves it? How does it sound? I'm super tempted to sell my speakers and get those.
#60
It probably sounds amazing! The speakers Lexus put in the car aren't bad but I bet they are not up to the quality of those or the ML amp to be honest. It's like the tires they put on the car; they are good but Michelin's are better
MOB561 (08-27-20)
