headlight condensation. Help Please.
hey guys a couple days now i have observed my headlight on the driver side is getting condensation. I want to check the drain tube to see if it's blocked, does anyone know where it locate at? if the drain tube is not blocked, does anyone know any other way to fix it?
Typically this happens when a seal fails just enough to let moisture in but not enough to let it out. Aside from resealing the entire unit, you can create a larger hole somewhere by either leaving a cap off or drilling a small hole somewhere to act as a moisture vent.
Here's the logic... when the headlight is on, the air in the housing is hot and expands. When switched off, the air begins to cool and contract, drawing in more air from the outside. Especially if the car is parked outside, and in the evening/night, you're talking cooler damp air being drawn in, hence condensation on the interior on the lens. You will likely need more than a small hole to vent properly. (At least this is what my logic tells me...)
