HID to LED conversion headlights.
Old Nov 19, 2019 | 06:40 AM
NIAautoDesign's Avatar
NIAautoDesign
Former Sponsor
Default HID to LED conversion headlights.
We have a 2015 GS350 that we are working on. from my understanding they come with HID's but since one of the bulbs burnt, i wanted to update them to LED's. has anyone done it, if so any recommendations?
Old Nov 19, 2019 | 07:10 AM
peasodos's Avatar
peasodos
If you don't have the f-sport the triple beam led headlights is plug and play, but you also have to swap out the headlight swivel ECU located in the driver foot well area. Also you need to install an AFS off switch that plugs under the steering column, next to a couple other switches.
Here is the part number for the correct headlight swivel ecu for the led headlight:
89940-30270
INSTRUMENT PANEL, HEADLAMP SWIVEL, W/ ADAPTIVE, W/ LED H'LAMPS
I did this mod last year:
https://www.clublexus.com/forums/gs-...l#post10297094
... I just realized your talking about changing the bulb to led not the whole headlight assembly.
Old Nov 19, 2019 | 08:14 AM
GregCanada's Avatar
GregCanada
Why would you want a downgrade in performance? Unless you mean you want to switch out the entire assembly as peasodos mentioned.
Old Nov 19, 2019 | 08:34 AM
IntrinoX's Avatar
IntrinoX
LED bulbs in a HID projector is no bueno.
Old Nov 19, 2019 | 04:34 PM
NIAautoDesign
Former Sponsor
You scared me for a bit. yeah just the bulb. i figured just taking the ballast out and plug it in directly to power?
Old Nov 19, 2019 | 04:36 PM
NIAautoDesign
Former Sponsor
I always thought LED's would be better than HID's as of lasting longer and look brighter?
Old Nov 19, 2019 | 04:37 PM
NIAautoDesign
Former Sponsor
why is that?
Old Nov 19, 2019 | 07:45 PM
mrplesh's Avatar
mrplesh
LED bulbs will produce a lot of light, but they will not throw it far. The projector lease in our cars is designed for an HID bulb and will work great with it. LEDs will just throw light blinding other drivers and reducing your own visibility due to poor focus.
Keep the HIDs IMO
Old Nov 19, 2019 | 08:25 PM
DuB's Avatar
DuB
Also, the HID projectors are meant to focus light assuming the source of light comes from a specific location on the bulb. The LEDs won't be producing light in the same location, so the beam of light won't be as focused, and the cutoffs will be more undefined, thus blinding other drivers as mrplesh mentioned.
Old May 5, 2024 | 03:10 PM
maxlegends's Avatar
maxlegends
3rd Gear
resurrecting this thread
If I have a 2019 with standard headlights, would I need the ECU ?
Thanks
rxsuperman
RX - 3rd Gen (2010-2015)
39
May 6, 2024 11:51 AM
Vdang
Aug 10, 2018 09:21 AM
bmwlexus09
Jun 30, 2016 11:08 AM
super400
Feb 16, 2016 04:26 PM
sleets88
Nov 5, 2014 02:13 AM
