Green Valve Caps
Old Aug 22, 2019 | 01:39 PM
DAVEB1980's Avatar
DAVEB1980
Default Green Valve Caps
The dealer told me that since my 2018 GS350 has green valve caps it means I have Nitrogen filled tires. Do I have to go back to the dealer to get tires filled or topped off or is there another way?
Old Aug 22, 2019 | 01:55 PM
peasodos's Avatar
peasodos
You can just top it off with regular air. I'd probably change the caps since green looks ugly. Just an unnecessary thing the dealer did to get you to go back, then they will suggest other unnecessary things to bill you. The whole point of Nitrogen is psi won't change with the temperature fluctuations, but in reality that's not the case.
Old Aug 22, 2019 | 02:02 PM
bclexus's Avatar
bclexus
If you want to continue using nitrogen you'll have to go where nitrogen is offered, and you'll likely be charged for it. As you probably already know, nitrogen molecules are larger and therefore will not be lost as quickly through the tire's carcass as regular air. But, the reality is - there's not much difference between using nitrogen and regular ol' air.
The regular air we breathe is 78 percent nitrogen and the rest is oxygen. The nitrogen in your tires is never 100%, so if it is say 90% - 95% nitrogen it is only has about 12% - 17% more nitrogen than regular ol' air. That said, most people do not find it worthwhile to use nitrogen in their tires.
Old Aug 22, 2019 | 05:00 PM
chinee's Avatar
chinee
Reading this thread just reminded me that I've been wanting to change out the dull silver-grey caps on my GS and replace with black or gunmetal... I'll be checking Amazon tonight!
Old Aug 22, 2019 | 09:15 PM
baconRx's Avatar
baconRx
nitrogen is a scam, easy upcharge for the stealership and hard for anyone to prove they actually use nitrogen. who says they even refill with nitrogen even if you have the nitro caps.
Old Aug 23, 2019 | 05:11 AM
DAVEB1980's Avatar
DAVEB1980
Originally Posted by bclexus
If you want to continue using nitrogen you'll have to go where nitrogen is offered, and you'll likely be charged for it. As you probably already know, nitrogen molecules are larger than and therefore will not be lost as quickly through the tire's carcass as regular air. But, the reality is - there's not much difference between using nitrogen and regular ol' air.
Thank you professor proton! hahaha
Old Aug 23, 2019 | 05:12 AM
DAVEB1980's Avatar
DAVEB1980
Good point the green caps are FUGLY...need to upgrade. Does the dealer offer Nitrogen?
Old Aug 23, 2019 | 06:35 AM
praetor's Avatar
praetor
Costco uses the green caps and offers free top offs. Being that normal air is 78% nitrogen, you won't see a huge difference between regular air and nitrogen filled tires. It does help though.
Old Aug 23, 2019 | 06:39 AM
DAVEB1980's Avatar
DAVEB1980
I am a Costco member.... will check that out. Thanks for the information!
kchnew
NX - 1st Gen (2015-2021)
15
Nov 21, 2019 08:48 AM
GRPFAN
RX - 3rd Gen (2010-2015)
29
Mar 19, 2012 05:00 PM
Frosty250
Jun 30, 2010 11:35 AM
USCRugby
Oct 18, 2008 05:23 PM
Tjz
Jun 23, 2003 07:16 PM
